nene's Avatar
Valve adjustment.......should I be concerned???
For the first time, I am shooting to do my own 86 Carreras valve adjustment. It took my various hours just to take the rusty bolts off of the CAT. Well, finally did it the next day. I took all of the misc parts so I could then take the valve covers off. One look inside, and what do I see............the rocker arm sliding out of the housing!! WT#%$#%$! What do I do in these case....sell the car (JK)? Do I just tap it in and then tighten the Allen bolt that is holding it there? I have no idea and decided to call it a day and refer to my Amigos at Pelican, Gracias!!
Old 09-23-2013, 08:40 PM
Push it back and torque it a little higher than specs.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 09-23-2013, 09:10 PM
ROW '78 911 Targa
timmy2's Avatar
Loosen a little, push it back and torque it to 20 ft/lbs not 11 or 12 like the book says....
BTDT...
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 09-23-2013, 09:18 PM
nene's Avatar
When you say loosen, I assume loosening the allen and then tightening?
Old 09-23-2013, 09:29 PM
Send a message via Skype™ to Porboynz
Well are you not lucky to find this before it moved all the way out. I would remove it and inspect in case the rocker has been grabbing on the shaft and causing it to walk out of the housing. If it all looks fine, reinstall and retighten and move on.
1972 911T Coupe with a '73E MFI engine and 'S' pistons
10 year resto mostly completed, in original Albert Blue.
***If only I didn't know now what I didn't know then***
Old 09-23-2013, 09:34 PM
Go-Kart Mozart
JAR0023's Avatar
Yes. 5mm on one end. IIRC 8mm on the other. -J
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 09-23-2013, 09:47 PM
ROW '78 911 Targa
timmy2's Avatar
2 Allens to loosen, one on each end, and as porboynz noted, take a good look at the bore for any damage. Inspect the shaft and rocker bushing for damage and clearance as well.
Mine:
Finally, back in the game!
Dennis
Old 09-23-2013, 09:50 PM
nene's Avatar
Question, does the shaft not spin with the rocker? Or does it stay put, and just the rocker rocks?
Old 09-23-2013, 09:56 PM
ROW '78 911 Targa
timmy2's Avatar
Shaft stays put, rocker does the moving.
Dennis
Old 09-23-2013, 10:00 PM
nene's Avatar
Timmy, so does the pressure of the Allens on both sides keep it put? and do you think that the shaft was not tight enough?
Old 09-23-2013, 10:03 PM
nene's Avatar
Has anyone seen where the rocker falls off and cause damage?
Thanx to all!!! Now I can sleep!!
Old 09-23-2013, 10:04 PM
ROW '78 911 Targa
timmy2's Avatar
The cone washers on both ends expand the shaft on the ends to keep it in place. Friction fit.
Dennis
Old 09-23-2013, 10:38 PM
Weekend Mechanic
vulcan300's Avatar
I saw this in an SC I worked on a couple of years ago, only in that case half of the rockershafts were loose. Check all of the rocker shafts for proper torque. It's not the end of the world.
86 911 Carrera Targa
Old 09-23-2013, 10:59 PM
