| Registered |
				Valve adjustment.......should I be concerned???
			For the first time, I am shooting to do my own 86 Carreras valve adjustment. It took my various hours just to take the rusty bolts off of the CAT. Well, finally did it the next day. I took all of the misc parts so I could then take the valve covers off. One look inside, and what do I see............the rocker arm sliding out of the housing  !! WT#%$#%$! What do I do in these case....sell the car (JK)? Do I just tap it in and then tighten the Allen bolt that is holding it there? I have no idea and decided to call it a day and refer to my Amigos at Pelican, Gracias!!    | ||
|  09-23-2013, 07:40 PM |
| Registered Join Date: Oct 2001 Location: San Carlos, CA US
			Push it back and torque it a little higher than specs.
				__________________ Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 | ||
|  09-23-2013, 08:10 PM |
| ROW '78 911 Targa |
			Loosen a little, push it back and torque it to 20 ft/lbs not 11 or 12 like the book says.... BTDT...
				__________________ Dennis Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds. | ||
|  09-23-2013, 08:18 PM |
| Registered |
			When you say loosen, I assume loosening the allen and then tightening?
|  09-23-2013, 08:29 PM |
| Registered |
			Well are you not lucky to find this before it moved all the way out.  I would remove it and inspect in case the rocker has been grabbing on the shaft and causing it to walk out of the housing.  If it all looks fine, reinstall and retighten and move on.
				__________________ 1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** | ||
|  09-23-2013, 08:34 PM |
| Go-Kart Mozart |
Yes.  5mm on one end.  IIRC 8mm on the other.  -J
				__________________ 86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken | ||
|  09-23-2013, 08:47 PM |
| ROW '78 911 Targa | Quote:
 Mine: Finally, back in the game!
|  09-23-2013, 08:50 PM |
| Registered |
			Question, does the shaft not spin with the rocker? Or does it stay put, and just the rocker rocks?
|  09-23-2013, 08:56 PM |
| ROW '78 911 Targa |
			Shaft stays put, rocker does the moving.
|  09-23-2013, 09:00 PM |
| Registered |
			Timmy, so does the pressure of the Allens on both sides keep it put? and do you think that the shaft was not tight enough?
|  09-23-2013, 09:03 PM |
| Registered |
			Has anyone seen where the rocker falls off and cause damage? Thanx to all!!! Now I can sleep!! | ||
|  09-23-2013, 09:04 PM |
| ROW '78 911 Targa |
			The cone washers on both ends expand the shaft on the ends to keep it in place. Friction fit.
|  09-23-2013, 09:38 PM |
| Weekend Mechanic Join Date: May 2008 Location: Toronto, Canada
			I saw this in an SC I worked on a couple of years ago, only in that case half of the rockershafts were loose. Check all of the rocker shafts for proper torque. It's not the end of the world.
				__________________ 86 911 Carrera Targa   | ||
|  09-23-2013, 09:59 PM |
