air/fuel ratio gauge
I installed an Innovate DB air/fuel ratio gauge in my SC over the weekend. Other than having to source a mounting bracket and build an extension for the LC1 cable, the installation was pretty straight forward and well documented. I've never had one of these gauges in a car before and did not know what to expect. I've got the CIS set just slightly richer than stoichiometric at 13.6. When I rev the engine, the a/f ratio stays about the same up and down the rev range. When I first open the throttle, it leans up just a bit, maybe up to 14 or so and when I let off the throttle it goes slightly rich, down to around 12. I haven't had a chance to drive the car yet, but I guess that I was expecting the system to get slightly richer as the rpms went up. So far, I haven't seen that. Of course, actually driving the car and putting a load on the engine will be different than just revving it up. Anyone have experience with these things?
Thanks,
FEC3 1980 911SC coupe "Zeus" 3.3SS god of thunder and lightning |
Banned
Fred, I have an LM2, and I can tell you that revving the engine at a standstill is going to show you nothing useful - you won't see any enrichment on the meter because without a load, the engine needs/uses very little fuel (even at higher RPMs). It looks like you already realize this, however . . .
ROW '78 911 Targa
Sounds normal, post what you see when driving, I'd like to see the numbers.
Reiver
Are you tied into both banks of the engine? I've an AFR that is only getting results from one SSI so I took it to a shop to check the total CO so I could adjust properly.
I moved the gauge dial face to show the tailpipe CO. Yours sounds normal...AFR is a moving target based upon air density and the engine temp/fuel metering. I like to see idle at 13.2 or so and run, when hot in 90 degrees about 13.50 to 13.75. on a Euro SC 930-10. |
Exhausting......
Reiver
The AFR gauge registered a co of 4/ 13.00 on one bank when the computerized emissions tester registered 3.2/13.31 out of the tail pipe. Quite a dif. New AEM gauge with Bosch lamda. |
My favourite subject !
Measuring CO or AFR levels at the tailpipe is not the best of ideas (certainly not at idle and lower RPMs). Look at the attached graph. Having said that I have been running around with an LM 1 for years and I would be intrested in Freds observations on AFR at load and different RPMs. Also at WOT and what happens to the AFR ratio when the throttle is suddenly closed. ![]() Michel
My dad always found an excuse why not to buy a Porsche, so I guess I am all out of excuses. |
Max Sluiter
Well of course if you have a cat it will be different. Cats are designed to oxidize CO to CO2, and clean up the hydrocarbons and such. NO to NO2.
1971 911S, 2.7RS spec MFI engine, suspension mods, lightened Suspension by Rebel Racing, Serviced by TLG Auto, Brakes by PMB Performance |
El Duderino
Reiver
Every Porsche shop measure CO at the exhaust when setting CO....that's not good? |
Max Sluiter
I was just replying to the graph which talks about a cat. I have a 2.7 RS spec so no cat.
Max Sluiter
My mistake. They work to put it back to O2 and N2.
Reiver
I was talking about that too......I had a pretty wide variation in AFR/Co from my one SSI compared to my tail pipe analysis....I have no idea what a cat would do to the mix but it could only muddy the waters some.
Max Sluiter
OK, I misunderstood your post. I am not sure why the variation. Cam timing different side to side? Maybe the heater boxes effect things like thermal reactors did?
Reiver
The engine has a fresh rebuild and runs like a top...even slight differences in injector performance could make a huge dif. That was my point btw, if you run an AFR lambda on one bank only get your tailpipe CO analyzed for confirmation or deviance. Just common sense. |
I have a Gunson tester so I will be able to ck at the tailpipe. Will do that "soon".
The differences in co or AFR measured between the exhaust pipe and a bung before the cat are the same whether you have a cat or non cat car.
If you look at a 911 SC Euro you will find a Lambda probe hole in the exhaust before the part where the cat comes (on US cars). If you put the LM 1 or 2 in that hole or in the exhaust you can find the same graph as depicted above. As you will notice once the revs go up the lines fall in-line. At low revs or no load on the engine the exhaust has a tendency to suck in air at the outer edges of the tailpipe, which increases the air in the total ratio. Once the revs and load go up the problem goes away and the measurement is the same. Yes most measure at the tailpipe as it is the easiest approach, but you will also notice that some have a tool to insert the sniffer as far as possible into the exhaust. Some exhausts are prohibitive At the emissions control in Belgium some will ask you to rev to 2.5k when checking the co. They are aware of the problems with measuring at the tailpipe and the positive effect it has on Co. All this to say that if you measure AFR at idle and you read 13.4, your are most likely a bit too rich in reality. Michel
My SC has been retrofitted with SSI exhausts and thus has no cat.
