ideas for mfi lines and hardware clearcoat
we buffed up the mfi injection lines and hardware on a 72T. We put a coat of wax on them but does anyone have any suggestions for some type of protective coating?
would you recommend a high temperature clear coat? and if so what brand thanks
1975 911S Targa Silver Anniversary Edition |
With the heat involved being on top of a hot engine...I was thinking...does VHT have a clear coat paint?
Bob
Bob Hutson |
Best stuff would be the ceramic based clear coat that's applied to plumbing fixtures and brass door hardware.
Porsche, aucune comparaison |
do you know any brands
any brand names for the ceramic clear coat?
I used this on hard fuel lines, brake lines, etc.....Eastwood Diamond Clear Satin Set
For longevity, engine parts coatings should be able to resist not only anticipated heat levels, but also to chemicals and solvents found in and around the engine compartment. This includes oil, fuel, brake fluid and cleaning solvents.
In that regard, these products are highly rated: Cerakote Coatings Cerakote Coatings In addition, these products have good wear characteristics and are available in a variety of colors and clears. Some are air-dried; some are heat-cured. Depends on your capabilities to prep and apply. There are also shops that do both types. Sherwood (no affiliation) |
VHT clear. but you waxed.
Steel lines can also be zinc coated (clear), but most places will charge a minimum fee. Suggest having other items processed at the same time.
Sherwood |
