wwest's Avatar
URO Parts DME Relay FAULTY
Email sent to URO parts/APA Industries:
You should RECALL all DME relays.
I have 2 at the moment and both failed out of the box due to poor soldering techniques/procedures during manufacturing.
In both products the 2 relays were not fully inserted through the circuit board allowing solder to flow over, bubble up, the connection and never bond electrically.
Second, not enough heat was used to get the solder to adhere to the relay metal frame/armature.
I needlessly spend many hours over 2 days thinking the new DME relay I purchased to replace the failed factory was good.
That relay had a poor solder connection from pin 30 to the back side, solder side, of the circuit board.
Once I found that the URO DME relay that I had just purchased was faulty I purchase a second one and my engine fired right up.
But..
In opening the second one I noted the very same manufacturing flaws.
So I desoldered both relays from the 1st purchase and carefully re-soldered them. It took a high power soldering gun to get a good electrical bond to the relay frame, armature connection since there is so much metal heat sink to heat up.
I'm going to stay with the relay that I "remanufactured" and put the second one aside as a spare.
Old 10-02-2013, 02:27 PM
mspirito's Avatar
URO equals China equals crap
I looking for a master cylinder and found that most of the ones offered from the different suppliers were URO
I OPTED TO SPEND TWICE AS MUCH FOR THE ATE VERSION
Old 10-02-2013, 03:01 PM
muck-raker
kidrock's Avatar
I wasted quite a bit of money several years ago buying URO crap for a Land Rover I once owned. The URO crap lasted only a couple of months at best.
That being said, I recently purchased the URO amber fog light lenses for my '88 - both lenses delivered for under $100, real glass too. Nothing mechanical to fk up, so I took a chance.
But I will never buy another mechanical or electrical URO part again. Pure JUNK.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 10-02-2013, 03:06 PM
Rescuer of old cars
Arne2's Avatar
I had a URO oil pressure sender for my 3.2, was poorly machined where the sealing washer sits causing an oil leak.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 10-02-2013, 03:47 PM
Slippery Slope Victim
NY65912's Avatar
Happens to the best of us and DME's as well.
Sure, be a big man and order the Porsche factory DME relay!
MikeČ
1985 M491
Old 10-02-2013, 04:04 PM
dtw dtw is offline
GAFB
I put the URO sump screen in my '72 911. Just did an oil change and inspected the sump screen (I have the sump cover with no !$!@%$ drain plug). It looks as though it will need to be replaced at the next oil change. As stated above, cold/poor solder joints. When shopping for parts, I'm now careful to avoid URO like the plague based on my experience and testimonials like the above.
Several BMWs
Old 10-02-2013, 05:15 PM
urine parts, made on a hibachi in north china
07 GT3 Cup S 4.0, 00 986, 78 911 old school gt car
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-02-2013, 07:00 PM
GaryR's Avatar
Send a message via ICQ to GaryR
And here I thought all the urine parts came from south china... never cease learning from you!
Bastards are making those red seals now too!
A Hibachi? LOL!!!!
Gary R.
Old 10-02-2013, 07:13 PM
That's a step up from the fire pit they used to have
77 BMW R100S
99 Ducati 996S
04 BMW R1150R
DanielJacobsLLC.com
Old 10-02-2013, 07:15 PM
GaryR's Avatar
Upscale Chinese Porsche Parts Foundry - rice wine will be server later
Gary R.
Old 10-02-2013, 07:39 PM
