what causes backfire
What causes an engine to backfire?
Glenn 911S - 1976 |
Generally, backfiring happens when combustion takes place outside of the combustion chamber--either on the intake side or the exhaust side. In a fuel injected 911, there are several possible reasons, usually determined by where the backfire is located and under what circumstances it occurs. Backfiring though the intake can be from timing issues, ignition issues, or from too lean fuel mixtures, among other reasons. Backfiring from the exhaust can be from overly rich fuel mixture, leaks in the exhaust system, or ignition problems, among others. If you want help on your specific vehicle, let us know year and model as well as where and when the backfire occurs, plus any history as to when it began and any work done to correct the issue.
L.J. Recovering Porsche-holic Gave up trying to stay clean Stabilized on a Pelican I.V. drip Last edited by ossiblue; 10-08-2013 at 01:17 PM.. |
Backfiring into the intake makes a popping sound. Exhaust backfires can simply sound like subdued firecraskers in your exhaust. If enough fuel collects in the exhaust, you can get that infamous ka-pow gunshot sound. I've seen mufflers laid open from backfires.
72 911T 2.4 MFI 2017 Escape SE 2.0 turbo 2020 Honda Civic Touring Sport 1.6 turbo 10' Madone 5.2/17' Lynskey ProCross |
Mine started backfiring on the second to third shift under hard acceleration after I replaced the cat with a straight through pipe. I am assuming that this is due to excessive fuel in the exhaust.
Been doing this for over ten years with no damage to my engine. Your results may differ.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
Additonal intake backfiring can be cause by vaccum leaks.
Alex ____________________ 1977 Porsche 911S (Daily driver) 1972 Porsche 914-6 GT Clone (Project) |
86FlatSix
I experienced a backfire since I installed Fabspeed Supercups (1in 1 out). It normally occurs if I downshift and just cruise along followed by a burble sound upon deceleration, normal? Never had the backfire on my stock muffler until the install.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) Last edited by JQ911; 11-12-2013 at 10:21 PM.. |
Senior Member
Recheck your CO2. Be absolutely sure you sealed all of your exhaust connections with new gaskets and that there are no leaks. Remove your oil cap at idle and note if the idle falls (it should).
'78 Targa in Minerva Blue |
86FlatSix
Yeah, I noticed a slight drop in my idle when I checked the dipstick a few days ago...Will check the gaskets.
74 BMW 2002 (rust rocket) 86 911 Coupe (weekend warrior) 09 997.2 C2 (semi-daily) |
I recently blew up my airbox on my '76 2.7L. The car had not run for about 13 years and I was so excited to get her running and get a few miles on her to see what needed to be worked on next, that I put off the installation of the pop-valve. So, with the pop-valve sitting on the back seat on a cold morning a few weeks ago....turn the ignition key and an instantaneous BOOM!
Now I'm planning out my first engine drop! Test stand and adapter ring ready to go.
1976 911S, sleeping for 13 years, back to life in 2013! |
