ADDvanced's Avatar
Need more details on rebuilding starter solenoid
So I took my starter out, regreased the bearings in the starter motor, spins nicely, and removed the solenoid. I desoldered the wiring coming from inside the solenoid, and removed the cap. I read about an "x" shaped contact, but I don't have that. I just have what looks to be a hand made piece of copper shaped like a straight line. I also don't see how there could be any sort of X shaped contact, as there is plastic inside the solenoid that prevents any such shape from existing.
Anyway... what now? What exactly do I regrease in the solenoid, and what type of grease? Dielectric grease? High temp? ??? Again, I searched but i could find no answers.
Old 10-09-2013, 11:05 AM
pete3799's Avatar
SOLENOID and STARTER rebuild......finally
Pete
79 911SC RoW
Old 10-09-2013, 12:55 PM
ADDvanced's Avatar
Right, I'm at that point, but I've read of people "relubing" the solenoid... that doesn't really have any info on that part. What part do I lube, exactly?
Old 10-09-2013, 01:23 PM
ADDvanced's Avatar
Forgot to update this post: Slapped some fresh lube on the solenoid, reassembled, reinstalled, BAM. Problem solved. Way cheaper than a new starter.
Old 12-03-2013, 12:46 PM
what lube did you use?
65 356SC Cab - 70 T Sunroof Coupe - 82 SC Targa - 86 Coupe - 87 Targa - all sold years ago
89 944S2 Daily Driver-Sold because...still thinking why.
73.5CIS Targa Shed Find -On the Road Again
Old 01-03-2014, 04:50 PM
ADDvanced's Avatar
High temp grease
Old 01-04-2014, 09:14 AM
