mca mca is offline
mca's Avatar
Just so you know, the oxs relay under pass seat may fail intermittently before it completely fails. You should always carry a spare. Might as well buy two and replace existing relay - keep other as spare.
Be sure to check your dizzy cap as the securing clips can loosen. Since you recently replaced it, figured I'd throw that out there.
Old 10-13-2013, 05:50 PM
you see Arthur...
jasonlee's Avatar
thanks. I will order a relay from our host
i will also check the resistance of the WUR tmrw. i will advise. Thanks for all the help
J
82 911 SC, Cat bypass, Flowmaster 1 in 2 out lightweight flywheel and backdated heat
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 10-13-2013, 06:44 PM
you see Arthur...
jasonlee's Avatar
what kind of reading should I be looking for in regards to resistance on the WUR?
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 10-14-2013, 10:56 AM
Sub'd
'The forever project car - 1979 911SC targa - getting it running right was a task, read about it here: http://forums.pelicanparts.com/911-engine-rebuilding-forum/722362-dads-911sc-i-am-finishing-rebuild-long.html
Other cars: 1993 Corvette LT-4/ZF6, polo green. 22 Ranger 4x4 with a couple cool things.
Old 10-15-2013, 07:21 AM
Correction..........
Originally Posted by boyt911sc View Post
Jasonlee,
Do you have a USA/Can model car? If yes, then you should have a WUR-090 on it. RoW cars would have a different WUR. Remove the electrical plug from the WUR and use a multi-tester (VOM) and set at resistance (Ohms) Omega sign on the dial. There are two (2) terminals at the WUR and place the probe tips. The car should not be running when you do the resistance measurement. Or you'll blow the fuse of the multi-tester. Keep us posted.
Tony
Walt F. caught my attention about checking the heater resistance with the FP or engine running. With the electrical plug to WUR removed, the WUR has no power supply thus a running FP/engine would not have any effect in taking the resistance reading or measurement. Thanks.
Tony
Old 10-15-2013, 01:46 PM
you see Arthur...
jasonlee's Avatar
Hello all. Just got back from a very long business trip.
An update to the rough running SC. it turns out the WUR was fine. The issue was fuel and electrical. New fuel filter needed, and the O2 sensor relay. Just old and gave up the ghost.
Thanks for everyones input, and happy to have the car running again.
J
06 Cayenne S
00 ML 55 AMG
Santa Cruz Bullit
Old 11-09-2013, 01:24 PM
mca mca is offline
mca's Avatar
Great news! Thanks for the update.
Old 11-09-2013, 07:19 PM
