3.2 '86 HP increase
First, I searched the archives but couldn't find the info I seek.
My '86 targa has a Steve Wong chip, M&K pre-muffler and 1-in, 1-out muffler, which are great baseline improvements.
My question: What are the next logical group of improvements to enhance performance by a significant amount, while maintaining reliability? I'd guess this involves some combination of increased compression, displacement, twin-plugging, cam change, and chip mapping. Any views of particular combinations of these changes, or anything else?
Thanks, Jeff
Old 11-04-2013, 07:46 PM
If that wasn't enough, there must be something seriously wrong with your engine.
Old 11-04-2013, 07:59 PM
Chain fence eating turbo
Pieced together stock 930 turbo bits!
Old 11-04-2013, 08:13 PM
RETIRED
Joe Bob's Avatar
Suspension tweaking and driving classes.
2012 ML350 3.0 Turbo Diesel
Old 11-05-2013, 05:39 AM
Undocumented User
McLaren-TAG's Avatar
You've pretty much exhausted the low hanging fruit... like others have said, learn to drive the car to its limits or focus on the suspension because further engine upgrades are going to be expensive and net you little in additional power.
Old 11-05-2013, 05:45 AM
Sboxin's Avatar
Agree with others . . . OR - - - sell it and buy a 964 or 993 or 996 Turbo . . .
Regards,
2002 Porsche Boxster S Cobalt Blue/Blk/Blk
Crew Chief for Son's 1978 Porsche 911SC Original Porsche Mocha Brown 3.8L NASA race car
Previous Porsches: 1958 356 Red Coupe - 1972 914 Blue -1972 911T Coupe Aubergine
Old 11-05-2013, 06:16 AM
durn for'ner
livi's Avatar
Weight reduction.
Markus
Resident Fluffer
Carrera '85
Old 11-05-2013, 06:43 AM
scarceller's Avatar
Shorter transmission gear ratios. But this cost $$$
Sal
1984 911 Carrera Cab M491 (Factory Wide Body)
1975 911S Targa (SOLD)
1964 356SC (SOLD)
1987 Ford Mustang LX 5.0 Convertible
Old 11-05-2013, 06:48 AM
Keep what you have and put on some seriously sticky tires, maybe some performance brake pads, send your struts out to be rebuilt, replace all of your suspension bushings....then invest in some track time.
I think that as our cars age, it may be more prudent to get our rides baselined as stuff wears out.
That will provide a reliable driving experience.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 11-05-2013, 07:14 AM
Banned but not out, yet..
RSBob's Avatar
Thanks, Jeff
It appears the previous respondents are missing the point above - Jeff is willing to spend the coin to get the gain. So who can address his question on engine mods?
Old 11-05-2013, 07:51 AM
Grappler
Rodsrsr's Avatar
I would say his list is spot on, but by the time its finished he could have purchased a nice 3.6 for less. Or as Tippy said, join the boost club.
Grappler
Know Gi / No Gi
1976 RSR Backdate (Turbo 3.2)
Old 11-05-2013, 07:58 AM
The problem with the 3.2 is the smog cams. Cams with more overlap will not work with the fuel injection. If you make it breathe you will get a lot more power and throttle response but it will be at the expense of emissions and fuel economy. Some cams with aggressive valve overlap, 46mm PMO carbs or EFI, and headers with a sport muffler would make it scream. If you want to go even further you will need higher compression and dual plugging. It gets very expensive quickly. Or, as others have suggested, add a turbo.
Old 11-05-2013, 08:43 AM
Thanks, Jeff
I think you nailed the progression for "significant" power: + compression, + displacement, twin plugging and cam changes are all interrelated, and because of that you'll probably do it all at once. An improved exhaust system and a re-mapped chip for the twin plug ignition will surely follow. To further refine or incorporate, you could explore ITBs and a user-adjustable engine control system.
As others have suggested and depending on your particular engine condition/value and budget, a 3.6 or an already rebuilt modified engine might be a better starting or end point.
Sherwood
Old 11-05-2013, 08:54 AM
Thanks, guys, for the useful info. BTW, I have addressed the 'low hanging fruit' re suspension ... Bilsteins, euro lowered, aligned, corner balanced, Dunlop Direzza tires. The engine thoughts are dreams for the future. John Walker's shop is just a hop and a skip from my house
What set of mods is required for a turbo upgrade, or is the option to just replace the car?
Old 11-05-2013, 09:06 AM
Replace the entire car with a newer model or a turbo if you want more power.
Old 11-05-2013, 09:19 AM
But I love my car . Also I see inumerable posts here by folks who have $$$ modified engines, so I'd guess I'm not the only one to consider diving deep in the pool of economic foolishness
Old 11-05-2013, 09:22 AM
I would rather be driving
jpnovak's Avatar
The next simplest engine upgrade to retain NA would be:
98mm high compression pistons/cylinders (makes engine a 3.4)
993SS cams (probably won't pass smog but will work with Motronic)
twin plug heads (necessity due to bore and compression increase)
custom chip to make it all happy.
This would be a great engine.
Next from there would be to go to a bigger cam. With a bigger cam you need an new engine managment that does not use a barn-door style AFM. You could use manifold pressure (MAP) or mass air flow (MAF) as your new metering device.
If you go to a new EFI system you might as well go for the ITBs to make it really scream. Look at the recent post from D-Zug about the torque (and HP ) increase from an ITB setup.
Its a steep slippery slope. Have fun on the way down.
Old 11-05-2013, 09:31 AM
Thanks, jpnovak, that's just the info I was seeking. Pardon my ignorance, but what is EFI and ITB?
Old 11-05-2013, 09:49 AM
GaryR's Avatar
Send a message via ICQ to GaryR
EFI = Electronic Fuel Injection, you have an archaic version of it now.
ITB = Individual Throttle Bodies, such as what PMO sells to replace your whole intake system..
Gary R.
Old 11-05-2013, 09:52 AM
porsher
aston@ultrasw.c's Avatar
It's such a difficult trade-off between power, reliability and cash.
I like reliability with my power, so I went the 3.6/G50 route.
To avoid the cash issue, I never add up all the expenses!
86 911 Race Car, with a few 993 bits in the boiler room
79 928 Race Car
88 928 Becoming a Race Car
Old 11-05-2013, 12:19 PM
