polizei's Avatar
Reinstalling Axle on Carrera - Couple Questions
Hey Guys - I went to tech a couple weekends ago in preparation for Summit Point DE, and found a torn CV boot. I uninstalled the axle and am having a local shop clean the joints, re-grease and replace both boots. I'll be re-installing the axles tonight and had a few questions:
1. Do I need to replace the CV Joint Bolts even if they're in fine condition? If so, would these be available at an Ace Hardware or Napa?
2. Do the CV Joint Bolts need to be lubricated?
Thanks,
Andy
Andy - 1987 911 Carrera Coupe
Old 10-14-2013, 05:54 AM
Slippery Slope Expert
Steam Driver's Avatar
In my opinion the bolts don't need to be replaced if in good condition. The biggest issue I found with that is the condition of the inhex head relative to R&R the bolts.
Probably not available at Ace Hardware ; maybe in size but probably not grade. I don't know about NAPA. These probably aren't a good place to scrimp on money.
I use anti-seize on about everything myself, but that's just me.
Old 10-14-2013, 09:11 AM
aj88cab's Avatar
You do not want to use any lubrication or anti-seize on these bolts. The bolts and the threads in the flange must be clean and oil free, otherwise there is good chance they will back out over time.
'88 Carrera Cab 3.2 Diamond Blue Metallic - ERP Polybronze Bushings, ERP Monoballs, SW Chip, Bilstein Sports, 930S Steering Wheel, DAS Rollbar, Sparco 5pt Harness, Hunsaker Sport Seats, Dansk Pre-Muffler, MK 1in-1out Exhaust, Magnecor KV8.5 Wires
'86 944NA, Sunroof Delete, Track Rat, Full Cage
'72 914 1.7 Guards Red / '02 Audi S4 Light Silver Metallic
Old 10-14-2013, 09:24 AM
No problem re-using these. You have the bigger (10mm) bolts. They are very reliable.
-Andy
Old 10-14-2013, 01:14 PM
Reuse as long as your allen wrench fit is good. Do not lube.
If you need a rplacement, call Fastenal in King of Prussia. They are right in the same building as Karosserie(the high end collision place you see from the PA turnpike).
If you need help, send me a Private message, and I can come by and help on Saturday.
Christopher Mahalick
1984 911 Targa, 1974 Lotus Europa TCS
2001 BMW 530i(5spd!), Ducati 900 SS/SP
2006 Kawasaki Ninja 250, 2015 Yamaha R3
1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750
Old 10-14-2013, 01:20 PM
polizei's Avatar
Guys - Thank you all for the input. The old hex bolts reinstalled just fine - no anti seize.
Chris - Thanks for the tip on Fastenal. There's another just down the road from where I work in Oaks - I've never shopped there but good to know that quality hardware is available.
Old 10-15-2013, 04:52 AM
Mo money = mo parts
Don't forget to re-torque after a few hundred miles. Also, you may want to consider schnor washers, they help bolts from backing out.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-15-2013, 10:12 AM
