Registered Loser
Check out my #6 intake valve.
1987 Carrera 3.2, 110K.
I had no compression in number 6. What do think may have caused this?
Obviously I will be sending off the heads, but really didn't want to split the case.
Looking for advice on what may have happened.
Thanks.
Mike
Current Rides:: 1987 Red 911 Targa, 2007 R320 CDI, 2003 Red Dodge Ram Hemi, 1993 Beater Jeep Cherokee, Airbus A320
Gone but not forgotten: 1981 VW Scirocco S, 1989 Honda Accord Coupe LXI, F-16C (still my favorite vehicle!),MC-130P, C-130E, T-38, T-37, C150, C172, PA180
Old 10-14-2013, 02:40 PM
fred cook's Avatar
Exhaust?
Looks to me to be the exhaust valve that is damaged. Usually, when an exhaust valve has edge damage like that, it is due to a lean running condition. Of course, it could have been caused by a defect in the valve. If you were lucky, the broken piece may have gone on out the exhaust without hurting anything. Are there any damaged places on the top of the piston? If not, just send out the heads for a refresh. Looks like the valve seat will have to be replaced.
FEC3
1980 911SC coupe "Zeus" 3.3SS
god of thunder and lightning
Old 10-14-2013, 03:28 PM
Many things can cause that that include, worn guides, bent valve, detonation (other things will be damaged as well).
Looks like your guides are shot too, as there is a LOT of oil in the port. Don't be surprised to find broken rings, as well.
Steve Weiner
Rennsport Systems
Portland Oregon
(503) 244-0990
porsche@rennsportsystems.com
www.rennsportsystems.com
Old 10-14-2013, 04:30 PM
Registered Loser
Oops, you're right, that is my exhaust valve. My bad.
That does make me feel a little better that it's not an intake valve.
Hopefully the piece just blew out the exhaust.
I will be sending off the injectors and cleaning out the fuel rails.
I plan to send off the heads, pistons and cylinders for a full reconditioning, but looking for further opinions.
Thanks guys.
Old 10-14-2013, 05:08 PM
Chain fence eating turbo
Send them to "cgarr". Cheapest around.
Registered Loser
What is his company? Thanks
Old 10-14-2013, 05:14 PM
thumbdoctor's Avatar
Starts with worn valve guides then oil deposits build up on the outer edges of the valve until it starts to hold the valve open. The flame front from combustion cuts through the valve edge like a torch. Less damage is done to the valve seat because of its cooling mass of the cylinder head. There doesn't appear to be any tell tale signs of detonation.
Porsche, aucune comparaison
Old 10-14-2013, 05:35 PM
Quote de Tippy
Just PM him.
Old 10-14-2013, 05:50 PM
Registered Loser
Hello again, so finally had some time to get back in the garage.
With a trip to the hardware store I came up with a nice little weapon tool to loosen the rocker shaft 5mm nuts. I used a 5mm standard socket with a craftsman 1/4 wrench and a breaker bar. Worked like butter!!
After loosening all the nuts I preformed the surgery of taking out each rocker and putting it into its proper bag. It was fun actually.
I separated heads 1-3 and the cam looks real nice. No signs of wear at all.
I will do 4-6 today and maybe even take off off my pistons and cylinders.
Speaking of pistons and cylinders. Where do I send those to be honed and replated/measured.
Ideally I would love to have a shop re-ring them for me. Breaking a ring with a ring compresser sounds too easy to do and not realized I did it!!
Any advice would be great.
Mike
Old 10-25-2013, 07:29 AM
Check with Mark at Exotech in Plaistow, NH (www.exotechpower.com). He can do the heads, measure everything, and take care of the cylinders as well. Prices are very reasonable and he knows what he is doing. Tell him Matt sent you.
Old 10-25-2013, 07:46 AM
