915 to G50 Conversion on my Euro 3.2 911 SC
HI, Efren here ...some of you may know me over from the 911 Used parts department but besides selling parts I actually really enjoy owning my 911.
all that hustling is to pay for this "project" my True love. You will see not only my 915 to G50 swap but also the general transformation of my car. The ever so familiar "while I'm in there" phrase will get tossed around quite a bit. Really this whole project started because..... I could no longer stand the 915 transmission (sorry 915 fans) To me it was slow shifting, This coming from someone who had previously owned only G50 aircooled 911s. I drove around in my SC for a couple of years Pulled the engine/trans several times and was never really happy no matter the improvements. At one Point I planned to build the ultimate 915 trans acquiring: Euro factory Oil cooler kit 7:31 ring Pinion Low/Tall gears a Mag case LSD and other trick bits for what was suppose to be a Frankenstein 915 but none of that ever came to light and now those bits That I swore never to sell have found there way on the used parts section. Here is a pic of what my Euro engine/915 looked like before installing it for the 3rd time into the Sc ![]() The shifting of the 915 (even after the rebuild) got so bad (in my head) that I wanted to sell the whole car and just start over again. After coming to my senses and the fact that I have so much love for my lil Sc I decided that I had to give my car a proper gear box. The G50 can fit several ways ( I won't go into detail) but... I'm taking the short bell housing method No modifications to the Chassis Other than coil overs (not needed) and setting the stock torsion bars to a Neutral position (rather than removing the torsion bars and loosing strength in the chassis) I Will modify G50 Case Shift coupler Trans mount an a few other bits I already choose the REBEL RACING Coil over kit at the Rear w/ Bilstein Sport shocks that I had previously rebuilt. http://www.rebelracingproducts.com/images/coil-over-rearcokmoms1.jpg they offer this kit for $300 not bad really (looks pretty too) So far I have sourced most of the used items needed for the conversion such as G50 Pedals + master 3 hydraulic lines Shifter assembly Transmission mount reservoir + line Slave cylinder G50 starter I had a slightly used light weight clutch kit but will only be able to use certain parts due to short bell housing, more on these mods later. Will be posting photos of process so stand by Any advice or comments are well appreciated Last edited by Blackbyrd; 07-20-2013 at 04:21 AM.. |
Sounds cool keep us posted with pics.
Tony 91 964 c2 black/ Work in progress/Finally back on the road 85 EURO 930 Black slightly moded slowly reviving her 77 911tt EFI wide body red/ Slightly modified ![]() SOLD
300hp 1800lbs is the goal
subbed.
Any idea what size the g50 hardline/fittings are? They look bigger then brake lines.
The '66 912 Bastardization project has begun. Note to PO's: LAY OFF THE FREAKING BONDO!!!! The science was settled: Earth was flat. Galileo : Flat Earth denier.
Grappler
Cool project....I'll be joining you in the future. Please keep us posted on your progress.
Grappler Know Gi / No Gi 1976 RSR Backdate (Turbo 3.2) |
Schleprock
I would recommend looking at creating something like the Patrick Motorsports adjustable trans mount. It worked fantastic for our '70 Motodelta racecar.
G50 SBH Transmission Carrier Mount Porsche Part Distributed By Patrick Motorsports Point being is that I don't think the factory G50 trans mount is going to fit in terms of being a bolt-on installation. May require some massaging and that's what the PMS mount does- allows for adjusting the location of the mount. I'm curious why you're installing coilovers. You don't really need to, since you're not cutting out or modifying the torsion bar housing, correct?
Kevin L '86 Carrera "Larry" |
Brando
subbbb
Turbo powa! 1977 911s. it's cool |
I will start taking apart the car Tuesday
KTL wow good one! For $288 that is NOT bad, but fabricating my own might be lighter and at no cost. Now if I was someone who had zero machines and help from knowledgeable friends I would buy the Patrick motorsport steel 915 style trans mount they sell in a heart beat, Its pretty clever. Anyone know the weight ? I will use the aluminum G50-01 engine mount, modified though or how KTL puts it "massaged" photos of these mods coming soon. If I wanted to weld on the chassis (I don't) this might be a "cheaper" solution http://www.patrickmotorsports.com/part/pmp-g50sbh-930-78-85/ Coil over aren't necessarily needed you are right, but I still think there might be a issue with the axles too close ? also I could save money/time when it comes to corner balancing. If I really don't have to use them I most won't. One of the biggest reasons is because I'm getting the Rebel Racing coil overs at a GREAT price that I just can't pass up. As for the G50 hardlines they are standard G50-01 87-89 Lines factory pretty easy to get ahold of. Last edited by Blackbyrd; 05-03-2013 at 01:51 AM.. |
Almost Banned Once
Cool project. I like my SC the way it is but I have thought about doing the same.
Subbed.
- Peter |
Subbed, this is something I would like to do in the future to my car, looking forward to following your progress.
Cheers Al
People are mushy - Paul Hawkins on the merits of where to crash on the Targa Florio |
Grappler
I have the same coil over kit on my car, but I use them as helper springs in addition to T-Bars to eliminate squat with the turbo. I also welded in the RSR type gussets on the shock towers. They're not designed to adjust ride height when used with T-Bars so they wont help with corner balance. You really dont need them.
Been Awhile since I updated this:
The G50 conversion turned into a Slippery slope as my coworkers say. One project turned into a full blown 4 corner upgrade I can only work on the car 2-3 hours after work and only when My coworkers actually want to stay in to work on their one stuff... ![]() (cleaned the hell out of the fender wells, this was very enjoyable Now the new upgrade include: Boxster Calipers all the way around: Seeing how my car needed new rotors and pads in the rear I decided it was time to upgrade my brake power. NOT only for the braking power but also for suspension reasons. Seeing how the boxster calipers weight almost half of what the stock calipers weight it was a no brainer. ![]() SC calipers I purchased the full Rebel Racing mount kit Nice and light w/ a cool finish + hardware included. The twist is I'm not using the SS lines provide in the kit. Although they are good SS lines I would rather go with custom made hard lines. So it looks and feels stock....maybe even lighter too. ![]() The weight on SC caliper VS Boxster Caliper was about 18 pounds I will post a whole other thread about this conversion. Also replaced the master cylinder to 23mm Turbo (had one new in box) (link of conversion will be posted here) Next I addressed suspension: ![]() My suspension on my car is one of the weakest points. 1 corner of the car is higher than the other side and reversed at the rear not to mention struts feel blown. The Rear shocks are actually brand new from a previous "while I'm in there" project with the front I rebuilt the front end Bilstein for Boge Inserts Sourced from Rebel Racing Doing something a little different with the front end to save weight...more to come on this The rear end of the business: I picked up a Rebel Racing Rear Coil over kit from my friend over at BISMIMOTO (new up and coming Porsche Tuner) he was using them for mock up reasons. I was told I did not need coilovers since I'm modify the trans in such away that it's not necessary. Seeing how I got them in a trade from I couldn't pass up the chance to "bling" my car with more of Clints products. ![]() ![]() Due to the fact that used rear shocks (unknown miles) were installed on the coil overs I now have to take apart the rebel racing coilovers and pull out the old shocks...then modify my (newer) Bilstein Sport shocks to machine a groove for the circlip. (FYI: non Sport shock don't work for the coil over kit) Oil cooling system: Seeing how my car still had the trombone Oil cooler and SC Oil tank... I figured I would upgrade both. My old SC tank doesn't have the breather vent in the tank so the 3.2 Euro engine runs a little rich. So I picked up a complete Carrera oil tank from LA Dismantlers (they had a few to choose from) Ran it in the parts washer at work then dropped it off along with the Oil cooler at: lamfied ultrasonic in Carson One day turn around and the price was pretty damn good. Nothing came out of either the cooler or the tank but better safe than sorry. (cheap insurance to clean them) SO MOVING ALONG TRANSMISSION CONVERSION ITEMS Now back to actually doing the conversion. I already pulled out the following 915 items off the chassis that won't be used: Shifter assembly (few bolts) Shift Rod assembly Pedal assembly clutch line The pedals were a little tricky I had to remove the clutch line and the throttle cable ball pins 1 rod and 1 flat bar that go to the brake booster Then removed the lower Oil pump/steering rack cover Followed by two nuts that hold the pedals from the outside (this is why I like the 964 style pedals a little easier to remove) I will be posting weight differences between both kits. Since this is a popular subject. Located all the G50 items from the same Local Dismantler where I got the Oil tank (LA Dismantlers) at a reasonable cost Bottle for fluid + mounting bracket + blue fluid line Hydraulic line (long) Transmission Hydraulic line w/ slave Transmission mount Shifter assembly w/ boot G50 Pedal assembly with slave cylinder The only thing I could get was the Hydraulic line from the Pedal slave to the long line in the tunnel. That short line was cut in half to remove the pedals faster I assume. This line will be custom made (to look like stock) another update to follow.. with more photos I will being putting in a big parts order this coming week and will most likely take a couple of days off work to hammer away and finish the chassis portion of the conversion. more to come Last edited by Blackbyrd; 06-08-2013 at 11:47 AM.. |
Nice project Blackbyrd!
Karl ~~~ Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s. |
Yikes
This project has turned into a "while I'm there" I have been replacing all sorts of stuff and doing little mods here and there. A piece of advice "while you are in there" Replace the rubber bushings for the Throttle rod in the tunnel take 3 of them. Mine literally fell apart as I touched them. ![]() The front brake mounts being adapted. What no one tells you with these "bolt on kits" is that you have to actually modify the brake shield ![]() Or worse the little problems, This nut killed me for what felt like an eternity then my friend came along and in one smooth move cracked it with some pliers... seems the previous owner over tighten the line ![]() The next little hump in my adventure was this little bushing ! 901.423.227.00 (x3 needed) "while I was there" I inspected the throttle rod only to find that the bushings were in a state of deterioration ![]() ![]() Not to mention I found all sorts of dead leaves n dust... The bushing came on pretty easy all I had to do was pull the tabs holding them down then reverse the process.. If you have to do this from scratch you must (from back to front) - Bushing # 1 remove the coupler access plate and move the coupler/rod - Bushing #2 remove bolts for the hand brake and move/slide the hand brake over to access the bushing -Bushing #3 is under the shifter Lets hope I notice the difference In the Trunk: I removed the Brake booster to make space to drill a hole for a brake fluid line and also to add the new 23mm Master cylinder. ![]() Sorry about the flash (or lack of) This shows the line going through its newly drilled hole w/ the proper factory grommet. ![]() I had to also loosen and move a couple of Hvac lines...not a big deal (note: the fume lines in the trunk will also be replaced) ![]() This is the 23mm Master cylinder. I had to remove the Switches since they were 2 prong and the wiring on my SS and previous master cylinder were 3 prong...simple solution Also added the Carrera brake fluid bottle It was a simple bolt on. ![]() More progress to follow Last edited by Blackbyrd; 07-20-2013 at 04:32 AM.. |
You guys will not believe some of the ideas that are flying around for this car.
I keep adding more things to do to the list, some Radical never before others subtle touches. I won't give away all the secrets but I will share what I can. Stay tuned: Adding to my update Seems I'm working on my car 2-3 nights per week Doing what I can. Some sad news, It turns out my Chassis might be bent or heavily misaligned It became apparent when I first added my Fuchs and confirmed by a second opinion the other night. After all my mechanical work is done it will go to a frame machine Along with proper body work..... Looks like I will have to sell more parts on the used parts section ![]() moving along: Brakes I had to measure, scribe and cut the rear control arms to fit the Boxster brake Calipers + mounting kit. First had to modify the dust shield ![]() Here is the front Dust shield already Cut/shaped/filed (seems I got too happy and cut it a little too short) But did a much better job on the driver side, passenger side shield will have to be redone. Control arms This is what shops who sell these rear brake adapter kits don't mention upfront Now you see me: ![]() Still here ![]() Few minutes later after grinding ![]() This photo above shows the Rebel Racing brake mounts, seeing how they are coarse thread and I wanted to use the factory hardware I decided to go with a set a friend engineered, he just happen to have a set sitting in his drawers ![]() His version sits in a slightly different position, He says they grab the rotor a little better. You be the judge (he doesn't sell them only makes one offs for friends so don't ask) You will have to excuse my rusty rotors ![]() In this picture you can see how I cut the rear Dust shields The proper way really would be to extended the other side. ![]() This photo shows the dust shield on the opposite side I did a few other little jobs like clean up the wiring from the engine compartment In motion to remove virtually any items that can be removed from the engine bay. more to come Last edited by Blackbyrd; 07-29-2013 at 02:13 AM.. |
Schleprock
Gotta keep the ideas to a minimum or the car will never get back on the road. Believe me on this. Myself and others local to me have gotten seriously bogged down by trying to make the bestest greatest awesomest 911 EVAR......
![]() Why keep the shields? Especially if the car rarely ever sees rain like in Cali? Caliper position really doesn't matter that much. Honestly, one of the best positions is down low, from a center of mass standpoint. But that usually isn't practical for various reasons. Here's a good article on it April 2000 Actually 9 o'clock or 3 o'clock on the axle is best simply from the position of the bleed nipples- vertical. Vertical makes the bubbles get to the nipple the easiest! Thanks for the pointer on the throttle rod bushings. I'll have to replace those on my racecar for sure. The rod is floppy as can be inside the tunnel and for some reason I never bothered to look for a part to replace!
I've seen a few people mention this "unholy trinity" of throttle rod bushings in the tunnel, so I thought I'd take a peek. All 3 of mine had disintegrated and fallen out! Thanks for the pics showing how they are held in by those metal clips that you manipulate by hand.
