'78 SC knocking sound at 850rpm
Hello,
since I have the car, I always had this knocking sound while idling at 850rpm. sounds alot like a con rod bearing past its lifetime. but when I increase rpm's to 950, the sound disappears.
Usually con rod knocks increase when engine is revved and quickly become worse. Did you check valve clearance, I noticed if one cylinder has a loose valve clearance it sounds similar to a light rod knock.
Oil, temperature and pressure all OK?
Goose- "nothing a year in the tropics wouldn't fix" |
Hi,
no we didn't check valve clearance yet because the covers weren't leaking and I wanted to keep it that way for a while ![]() but, I guess it's about time now ![]() a friend of mine has it too, but only if the engine is warm (also a '78 SC) |
Hi, oil, temp and pressure all perfect
![]() maybe a little bit low at cold startup (3-4 bar) but normal pressures when warm (1 bar idling and +1 bar per 1000 rpm) |
Bad tensioner, chain slap?
Bruce |
Hi Bruce, allready had a bad tensioner on another 911, souded more rattling.
Try disconnecting spark plug wires one at a time. If the noise decays, it could be piston slap, sometimes a tight wrist pin that gets worse when warm. Generally rods and mains with excessive clearance also cause oil pressure problems.
Porsche, aucune comparaison |
clem911
check your heat shield over the cat for broken/ cracked mounts.
Make sure all the motor mount bolts are tight.
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Like the previous poster said loose wrist pin.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
Old intermediate shaft bearing end play? Maybe hunt the answer in the engine rebuilding forums too.
78SC coupe, Silver Metallic |
Reiver
If you have Mahle nikasil forged pistons they tend to make a knocking sound at cold start until warm, a trait of forged pistons.
Accelerate and the noise goes away. If you have Alusils it's a dif. issue. |
Straight shooter
You can get load knock if you drop rpm too low. You'll hear this on even new engines when they're about to stall.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
I was also thinking load knock, but 850rpm is normal idling speed.
Unless my ignition or fuel delivery is way off... |
Make America Great Again!
This may be a shot in the dark but I had something knocking at low rpm, turned out the POs wrench had screwed up the AC mounting bolts, which loosened, and the AC unit was bouncing while turning...creating a knocking sound. I retapped the bolts... Tightened it down, Knocking gone. I don't run the AC belt now anyway.
Rich |
Thanks, but no AC or smog pump present
One more shot...my fan pully was not aligned properly as well...I made sure that the shims were in correctly, tight, and not skewed... This was also a source of chatter, knock.
Rich |
