irl irl is offline
irl's Avatar
Send a message via AIM to irl
Boges have two diff sized spindles
Just to create a quick post for future searchers because I couldnt find the answer easily. Boges have two different sized spindles depending on the year and part number. Up to 73 they have a 16mm spindle and in 74 went to a 18mm spindle. Bearings, seal and spacer are the same size but the thrust washer and the clamp nut are different parts on 16 vs 18.
I wish I had known this as i did not use my 74 struts and sourced a second pair, had them powder coated and had it all back together when I discovered the washer and end nut didnt fit, I ordered the correct parts but would have rather had the larger spindle.
Just wanted to document this for future people.
79 SC unmolested
75 911 backdated RSR widebody
71 911T having fun skinny
63 356 outlaw frustrating purists
25 GTS
Old 10-21-2013, 07:10 PM
