1896 Carerra Pelican High Output alternator replacement fitting issue
Hi all,
I'm in the process of replacing the original alternator in my 86 Carerra with the Pelican High Output unit. Unfortunately after tightening the 6 alternator bolts to the fan shroud the fan ceased up - jammed.
I noticed that tightening the bolts also brought the alternator so far back into the shroud that the belt/pully would be obstructed by the shroud so it's almost as if the new part doesn't match my shroud properly and some kind of 'stops' need to be installed to prevent the alternator from mounting so far back into the shroud.
Does anyone have experience with this? Unfortunately Pelican is closed for weekend and I can't call them...
Thanks!
-Kale
Old 10-26-2013, 10:24 AM
OK... so I took the thing out of the shroud using a gear puller and compared it to my OEM unit.
It looks like I'm missing some spacers but no sign of anything on the Pelican website about this as an add-on part. Maybe they didn't send me all the parts? Take a look at the image and you'll see what's wrong here.
Anyone with experience with this I'd love to hear what you used to put proper spacing in there. I'm thinking this would be a very fine tolerance or I'm going to ruin the alternator bearings/etc if only slightly out of spec.
-Kale
Old 10-26-2013, 12:18 PM
Go-Kart Mozart
JAR0023's Avatar
You got an SC alternator instead of the Carrera one. -J
ETA: The Bosch number for the Carrera alternator is AL401X (reman) and AL401N (new).
86 Carrera
Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats.
H. L. Mencken
Old 10-26-2013, 06:52 PM
Different length alternators
This picture shows the Carrera alternator (long one on the right) and a 911SC alternator (short one on left.) They require different mounts, as JAR023 chart states.
Old 10-27-2013, 06:54 AM
they just sent you the wrong part.
206 637 4071
Old 10-27-2013, 11:24 AM
Ouch.. what a pain. The good news is that this one wasn't my goof - I double checked the invoice and I ordered the correct part so they shipped the wrong unit.
I hope the return doesn't become a headache (these things are $$$) since I've mounted the thing and removed it from the shroud. I'm sure it's perfectly good but it's got a few scratches from the process.
-Kale
Old 10-27-2013, 01:06 PM
Tags
alternator jammed
