It's a cold, rainy and crapy day here in Wisconsin today. Perfect day for some of my minor projects. Like my Double Arrow Demon that has been teasing me since I bought my car. Today was not his day! .
![]() ![]() This is the common bad ground problem with these cars. I purchased some Italian front lens's a while back. When I installed them had to do the mandatory removal of the housings to repaint them. What a huge PIA that was. Cleaned the grounds inside the housings with a dremel and a polishing wheel, still double arrows. ![]() Dremel with a sanding wheel, cleaned the grounds behind the bumper on both sides. Still nothing! ![]()
Mike '99 Isuzu VX, 2005 Audi A4 1.8T Quattro '96 BMW 328ic '73 911T Targa SOLD www.flickr.com/photos/fenderbender813 |
So I continued working my way back to the gauges. Found this ground point and it is a PIA to get at and clean. It was not that dirty but cleaned it anyway, inspected the wires. Still nothing.
![]() ![]() This is the drivers side just behind the hood shock. It is a 13mm nut and is a bear to get at, it is under the wiring harness and at an angle. Next pull the tach and check connections. Tach does not come all the way out as it is hitting my steering colum cover. Not sure how this comes off, did not want to break so I pulled the fuel gauge to look around and the oil gauge. I found it is really easy to pull the turn signal relay through the fuel gauge hole. Much easier than trying to get at it from under the hood. I wiggled it with the turn signal on and sure enough there it was. Got Him!!! ![]() The ground on the relay was pushed into the relay housing. I did not have another one so I used a pliers and pulled it back out, then filed it clean with a points file and WHAM the Demon is dead for now. ![]() I am just so happy now I know which way I'm turning.
muck-raker
Awesome!!! I seem to get a bigger hard-on when I successfully fix an electrical issue, rather than a mechanical one....probably because they're a bigger PITA on these cars.
Congrats!!!
STONE '88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended. ![]() Deny Everything; Admit Nothing; and Always Make Counter-accusations
Make Bruins Great Again
I love stories with a happy ending!
-------------------------------------- Joe See Porsche run. Run, Porsche, Run: `87 911 Carrera |
I also fixed the clock again, this time it was dirty points where it gets energized. Dirty from the oil I used the last time I fixed it.
PMB Performance
Talk to me about the clock. Mine works but is S-L-O-W (I also have to hunt down the double arrow demon).
The clock though. I grabbed a jewelers screwdriver and turned the +/- adjuster toward the + side... yeah? Doesn't seem to effect it, maybe even had the opposite effect. It used to work and work well...
Eric Shea - PMB Performance 855-STOP-101 We Restore Vintage Calipers www.pmbperformance.com |
Happiest when Tinkering
I fixed the clock real good! Congrats on the electrical fix they are a pain for sure.
" Porsche there is no substitute" I always liked that saying. Air cooled is the only way to go! 76 911 C.R.A.P. Gruppe #2 BIG time TURBO C.R.A.P. Bitz EFI/EDIS Now MegaSquirt 3 76 Blazer also restored by me |
I fixed my clock the exact same way!!!
88 turbo Guards red Targa slant nose, and yes I am a horsepower junkie, 3.4liter,7.5 to 1 JE pistons, Adjustable WUR, Imagine fuel head, 1 bar waste gate headers,allthe cis toys. Now apart to become the next EFI monster. fabbing my own intake, headers Individual throttle bodies, MS-3, pauter rods, Xtreme twin plugged heads, gt-2 evo cams cop's. 2019 Silverado 6.2L |
Thank you very much to share Mike.
I've the same problem and I'll check this relay ASAP, hope that I could killl the demon too ![]() JM |
![]() I gently blew air over the gears to make sure they were clean and add a few drops of household oil? I had to adjust the +/- to fine tune it as I need to do again. I had a fire from my battery shorting out and the clock stopped working again, trust me at the time I was not worried about it, figured the solder let lose when the battery shorted out. Not this time, it was the set of contacts on the weighted mechinism, when they make contact it gets energized and winds it untill they touch agian. This is the mysterious noise coming from our dash boards every 5-10 minutes.(Just a guess on the time) The points were dirty from the oil I used. I cleaned them with a shop cloth wraped around a small screwdriver with some contact cleaner. Working great so far just a little slow. I did not take any pictures of this now I wish I had. If I find some I will post them. Good Luck
I was told the satin alum. ring was too much bling I guess I transgressed
It looks good as is, it matches the radio. LOL
Function over form.
What radio?
Oh ok the mount is there for the radio but haven't put it in yet as I still have some welding to do and didn't want to fry another radio, thanks anyway the look kinda grows on you after a while doesn't it.
None of my business....but would the speedo not be easier to read if it were clocked in the other direction?
Don Booth 87 Carrera Coupe (Current) 70 911 T Coupe 74 914 |
Its just in there right now I haven't set up any of the guages yet but your right that would kinda suck that way
![]() I think it looks just fine. You could paint the trim black or buy the silver trim rings if it ever bother's you.
Nope like it the way it is.
