LinkBack Thread Tools Rating: Thread Rating: 2 votes, 1.00 average.
Air Medal or two
afterburn 549's Avatar
Switch cams From SC to 964 What HP Gain?
I have a 2.7 with SC Cams. Puts 155 to the ground.
What would be the expected HP if I switch to 964 cams ?
Your thoughts?
thanx
D troop 3/5 Air Cav,( Bastard CAV) and 162 Assult Helicopter Co- (Vultures) South of Saigon, U Minh Forest, Delta, and all parts in between
Old 11-01-2013, 08:51 AM
ROW '78 911 Targa
timmy2's Avatar
156 HP...
The gains are in mid range performance. You're really just moving the torque curve around.
Old 11-01-2013, 09:15 AM
Air Medal or two
If thats all then i am not interested. the SC Cams made a huge difference......but was just dreaming...
Maybe 964 would be better.......
Old 11-01-2013, 09:25 AM
964 generally gives slightly more power at high RPM than SC, at the cost of less low and mid range torque.
I'd be surprised if 964 made more than 5% difference to peak HP over SC - and for a car that sees street time, I would just stick with SC unless you have EFI - on the grounds that you'll probably never notice 5% at WOT - but you'll feel low/mid-range pickup every time you accelerate in traffic.
You can experiment with the SC cam timing to move the power band around, see if you like this/can put up with it, without needing to actually change the cams out. Factory used the same profile for a long time, with varying timing specs for different years.
'77 S with '78 930 power and a few other things.
Old 11-02-2013, 03:44 AM
Halm's Avatar
+1 That is my experience with a 3.0 motor.
'06 Cayman S
'16 Cayenne
'08 Audi RS 4
Old 11-02-2013, 04:04 AM
Air Medal or two
I will stay where I am at
2.7 - 155 HP / 155 TQ @ at 5500 RPM
I guess that is as gooder as it gets with out dropping the heads and cylinders.......not in the mood..LOL
Old 11-02-2013, 04:15 AM
Elombard's Avatar
If you are going to pull it all the way down to change cams, go ahead and do pistons with reliefs and get some mod S cams. Of course you will need carbs and SSIs....and and and :-)
Dream of mine to build one with matched cams/pistons/intake exhaust. Probably would not be that great as a street car. Although I had a 3.2 with PMOs and it almost ran like it was fule injected. Just amazing that they have the carbs worked out that well.
erik.lombard@gmail.com
1994 Lotus Esprit S4 - interesting!
84 lime green back date (LWB 911R) SOLD
RSR look hot rod, based on 75' SOLD
73 911t 3.0SC Hot rod Gulf Blue - Sold.
Old 11-02-2013, 07:01 AM
Air Medal or two
Thanx for the advise.....but carbs are too stone age for this Old guy.
Maybe some other kind if injection,,,(Not CIS) which i currently run.
The point being...if i can extract more HP with cams i am interested....
The SC cams have a LOT under the peddle, not all hype, not all tweekie.
Old 11-02-2013, 09:42 AM
safe's Avatar
With 964 cams you will need to enlarge the valve pockets in the pistons in a 2.7. Thats what I have been told by John Dougherty.
Magnus
Old 11-03-2013, 03:29 AM
