Wits end with blinkers
1987 Carerra. My right side blinker is in hyper drive.
My list of what Ive done.
So today I pull the right front lenses off as I notice the lights are rather dim compared to the left side. I clean up all connections on the right parking lamp, the blinker housing is recent. I put a new tag light bulb in as it had been out Then the **** hits the fan. same old deal no change until I turn off the ignition and the damn right side lights are still on! even with the key off!! wtf!. I bought a new blinker relay as I don't know what else would send volts to the blinkers with the car off. This is driving me crazy... I had to disconnect the battery. I couldn't find the darn relay, I thought it was under the bulkhead... Where is that booger? If the relay doesn't do the trick I'm at a loss. Is there another grounding area for the signals? New headlights and the wiring in the buckets is fine.Does anyone have a good diagram for the ignition switch and turn signal switch? I have a Bentley but it is not to clear on these items. I will hit this area next.
Speeds just a question of money, how fast do you wanna go? |
Definitely replace your blinker relay. I had similar strange intermittent flashing issues on my SC.
Second, in case you aren't aware of the European/German parking light function. When you turn the car off, if you 'click' the turnsignal lever either left or right the parking lights on that side of the vehicle will stay illuminated. Cooper |
Fast flashing is indicative of wrong current draw through relay, usually wrong wattage bulbs.
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) Last edited by theiceman; 09-23-2013 at 12:48 PM.. |
I had a similar problem and it turned out to be the piggy back (double prong) connector on the multi position headlight switch. It had come off. Worth a look.
78 911 SC "Scratchy" 2004 Mini Cooper S "Pele" (gone but not forgotten) 1979 classic mini clubman-"Coolio" |
Straight shooter
Have seen similar with wrong bulb used.
“Of the value traps, the most widespread and pernicious is value rigidity. This is an inability to revalue what one sees because of commitment to previous values. In motorcycle maintenance, you MUST rediscover what you do as you go. Rigid values makes this impossible.” ― Robert M. Pirsig, Zen and the Art of Motorcycle Maintenance: An Inquiry Into Values |
Yes, thought wrong type bulb could do this and went through most all of these, ordered many from our host as they are quite cheap and the right type.
I'll hopefully find the flasher and this will solve the issue... Oh and flip the sign switch off, I hope that was the reason they stayed lit kn that side. Very odd thing that lighting with ignition off, why is that I wonder? Thanks to all for the help and input. Does anyone know exactly where the right signal package is grounded? I though maybe at the ground lug in front of the battery... Also how does one remove these turn signal lights without bumper removal? Possible?? |
Make sure the wattage of all the bulbs is correct, and make sure the turn signal stalk is in the neutral position.
"A machine you build yourself is a vote for a different way of life. There are things you have to earn with your hands." |
With a standard type blinker relay...the current pulled through determines the blink rate.
With an electronic type relay...it blinks at the same rate no matter how many bulbs (or LEDs) are attached. Bob
Bob Hutson |
Carbster, if all else fails check the wiring at the lights themselves, the front bumper has to come off, then as in the rear lights the wires have individual spades. And it's tricky because its the same fixxture just flipped for the opposite side so it's a mirror arrangement of the wires.
It's happened to me, the wires get crossed so easily.
87 911 coupe, GP white, cashmere/black 64 Alfa Romeo Giulia TI - the violin 89 Peugeot 505 Turbowagon-other Pcar 67 912 coupe, white, sold 04 Audi Allroad 2.7T |
The Porsche is a European car. No such feature in US made cars for US consumption.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Not any more. More modern electronic flasher relays will fast blink as an indication of bulb failure.
ROW '78 911 Targa
Same with my US, California specified 79SC. It has all the European features plus it satisfies the American/Californian smog features, sugar scoop headlights, and all red colored tail light lenses. But it also has the European "parking light" functions: When you have the directional switch in a right or left position and turn off the lights and lock the car those directional lights stay on permanently. If you install H4 headlights they are even wired for permanent "parking lights" if you install the small 2 W light bulb in the H4 headlights.
79 SC Targa 72 T Targa Sold 68 T Coupe Sold 65 912 Coupe Sold 62 356B Coupe Sold |
.. some were sold in the US however
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
I swapped out the flasher with a pelican unit. No change, of course the blinker stalk back in neutral now. I still have dim lamps on the front right bumper. I need to trace this ground check and clean and verify the bulb wattage or number, 1125 for the turn signal I believe. The other parking lamp I need to verify but I replaced it with a unit specified for that unit.
Check all your grounds. Also check the seating of bulbs in the sockets
These cars are weird. I had a dim headlight and it turned out to be a loose tail light bulb... |
I had the same problem, bad ground wire to ground lug by battery. Ran a new ground wire to the lug for the fix.
