I need some advice on my Speedometer.
Running OEM size tire front & back. Earlier in the rebuild I sent the speedometer off to North Hollywood to be rebuilt... (the gear had dissolved during 16 years of storage and the unit no longer worked) I have chased wire and they appear to be good but... while driving it reads about ~30 MPH low. 30 @60, 35 @70 What else could it be? Bad Sensor?
Billy, MoosgrunMetallic - 81 911 SC - (Carbon fiber Wrap) Drank the Koolaid in 82 |
Inside the trans, on the pinion is a plate with 8 magnets. If one on the magnets drops off you loose 12.5% of your drive.
Standard replacement part and you can pull the pinion in the car. 915.318.045.03 Bruce |
Thanks that gives me a starting place & searches to dig though.
