click-clack noise when reving up - 1986 930
hi,
bought recently a 1986 930 US. The car has been sitting outside for more than a year, also not started for long time.
now, trying to bring it back on the read and came across a strange click-clack noise when reving up the engine. most of the times when engine is turned off this "clack" noise shows up too.
pls look into video and share your thoughts... it has "limited" quality but gives a clue about what i am asking about i guess...
Albin930 - YouTube
any ideas?
thanks!
Krzysztof
VW 1200 Sparkafer 1973
VW T2b Westfalia 1979
Porsche 930 Turbo Carrera US, 1976
911S 1976, 930 1986 - both gone
Old 11-09-2013, 11:40 AM
ganun's Avatar
First thing that comes to mind is the silicone washer bumper is shot. At the bottom of the pipe next to the pipe that feeds the intercooler
87 911 coupe, GP white, cashmere/black
64 Alfa Romeo Giulia TI - the violin
89 Peugeot 505 Turbowagon-other Pcar
67 912 coupe, white, sold
04 Audi Allroad 2.7T
Old 11-09-2013, 11:50 AM
thanks for the reply Ganun; can you please look at the pic below and help me point on the item that you think of here? is it shown here?
Old 11-09-2013, 12:14 PM
Banned
That noise is the sound of the diverter valve piston smacking against its housing end caps when you are suddenly closing the throttle - this happens when the washers/bumpers at each end harden and fall apart. The following is a detailed thread on that unit (although one of the posters, James Brown, gives out some wrong information about how the system on the 930 works) -
Changing 930 dump-gaskets, pictures galore
Old 11-09-2013, 02:29 PM
ganun's Avatar
Ronnie and I are talking the same thing but I don't see it in the parts diagram posted....
Old 11-09-2013, 04:00 PM
that is great help gents! many thanks!
last thing, though - any clue of the partnumbers of the gaskets/washers that need replacement here?
*edit: looked into PET and believe found the correct pn#: 930 110 149 00
will post up the diagram in a bit
thanks again,
regards,
Krzysztof
Old 11-10-2013, 02:51 AM
and now the diagram - item labeled with no. 7
Old 11-10-2013, 03:02 AM
Banned
Yep, you need two number sevens.
Apologies if you have already thought of this, but since you will need to remove the intercooler and the diverter valve housing, you need to make sure you have a supply of both sizes of intercooler o-rings and the larger o-ring that goes on the neck of the throttle body. I always order more than I need in case I manage to tear one of the new ones when installing (very easy to do).
small intercooler o'rings = 99970147340
large " " = 99970146940
o'ring between diverter valve housing and throttle body = 99970147740
Old 11-10-2013, 09:12 AM
perfect!
was not that quick if it comes to searching for o'rings so part numbers came in right on time :-)
will report back when new washers are in and all put back together
many thanks once again.
rgds,
Krzysztof
Old 11-10-2013, 09:53 AM
gaskets arrived and installed. issue solved :-)
one again, many thanks Ganun and Ronnie!
regards,
Krzysztof
Old 11-28-2013, 07:56 AM
Uncle Enzo's Avatar
I love a happy ending!
1976 911S
MidYear Fever is alive and well.
Old 11-28-2013, 09:22 AM
