Oil temp sender removal
Quick question. Is there a special tool for use when removing the oil temperature sender (82SC) from the case while motor is in the car. Can't find anything in my tool chest that will work. Thanks in advance.
Jack |
Do you mean the temp sender or the oil pressure sender? The oil pressure sender can be done in the car but you really need to remove the AC compressor and bracket out of the way.
Kurt |
ROW '78 911 Targa
Picture with arrow or pencil pointing to the device you want to remove would help.
Go-Kart Mozart
Maybe this will help. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
ROW '78 911 Targa
Nice picture.
![]() Now the OP needs to pick which one! ...
Thanks for the help JAR. Yes, the temperature sender. Looking for a tool or technique to remove it in the car. Can sacrifice the old sender with a chisle and hammer. Don't really want to do that. Has to be a less distructive way.
Jack |
83 911 Production Cab #10
No problem, I use chisel and hammer all the time when I build furniture…
Not found in the tool roll either
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
an open end wrench
-Bill 1979 911 SC Targa |
Bill
Or take an old box end wrench and bend it to the correct shape to clear the oil pressure sender.
Go-Kart Mozart
Offset box end wrenches are underrated. I consistently find myself pulling them vs. others. -J
remove the a/c bracket and do it right. the sender mounts on a steel block and it's bittchin tight usually. clamp the block in a vise and have at it. highly recommended to not try it with a crowfoot while attached to the engine. there have been a few sorry souls who broke the case in the process, so don't be one of them. read this...Broke of piece of metal, how to fix? jb weld horror story.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 11-14-2013 at 05:30 PM.. |
1976 Yamaha XS360 ( Beats Walkin') 1978 911 SC Targa ( Yamaha Support Vehicle ) 2006 Audi A4 2.0T (Porsche Support Vehicle ) 2014 Audi A4 2.0T Technik (Audi Support Vehicle) |
Bill
Wouldn't try to remove the oil pressure sender while on the car. Remove the whole thing and do in a vice. That sucker is on tight.
Thanks for all your input. On my way to HF this AM to buy a cheap box end or offset Yes it is the temperature sender as noted in the great pix JAR sent.
Jack |
good luck , shouldnt be much of an issue ...
do it when the engine is cold as you will get a bit of a burp and cold oil flows slower, just get ready with the new sender and sealing washer..
Just got a 20% off flyer from HF which should reduce the sting. Appreciate the encouragement ICE
Jack |
Bingo! Within 5 minutes of my return from HF the old sender was out and the new one in. Never had a set of offset box but I do now. Had completely forgot about this utility tool until JAR jogged my memory. Thanks for all your help. Now out for a drive to check it out.
Jack |
