Need help diagnosing non-starting condition
I'm trying to diagnose a no-start condition on my 88 911 and would appreciate some advice.
I'm pretty sure it's a fuel delivery issue.
I tested the fuel pump by disconnecting the DME relay and jumpering the harness. When I do so, I hear a momentary thunk which I'm assuming is the fuel pump. If I disconnect the jumper and re-connect, I get the thunk every time.
I should hear a continual whirr, shouldn't I?
Does this sound like a bad fuel pump to you?
Old 08-20-2002, 09:16 PM
http://www.pelicanparts.com/techarticles/911_carrera_start_troubleshoot/911_carrera_start_troubleshoot.htm
Old 08-21-2002, 07:47 AM
