Jacking with engine removed
Any suggestions how to safely jack up the rear of an SC once the engine/transmission are removed?
Once I've dropped the engine I want to drop it back onto its' wheels so that I can push it outside to pressure wash the engine bay. Then, obviously I've got to jack it back up to re-install the engine at a later date.
I'm not keen on using the side jacking points as it needs to be raised to a considerable height to get it back on axle stands in order to re-install the engine/transmission.
Old 11-22-2013, 12:23 AM
Brown747's Avatar
I use a section of 2X6 spanning the back edge of the pan, just forward of the torsion tube.
HTH Thor
1978 SC coupe #1834
Old 11-22-2013, 01:45 AM
Thanks,
I thought this might be the solution but was worried about floorpan strength.
Old 11-22-2013, 03:29 AM
HTH Thor
I did the same as Thor. The drivetrain represents a major % of the total weight of the car, and it's now gone. So there is a lot less stress placed in that area when they are gone. Using the 2x6 helps distribute that stress evenly over a larger area.
Old 11-22-2013, 05:07 AM
Your quite right, it'll be a few 100kgs lighter for sure.
Thanks.
Old 11-22-2013, 05:51 AM
Undocumented User
McLaren-TAG's Avatar
You can simply put one side down first and then the other.
Old 11-22-2013, 05:58 AM
83 911 Production Cab #10
JJ 911SC's Avatar
Thanks.
Around 600 Lbs
Who Will Live... Will See
Old 11-22-2013, 06:31 AM
