where does this wire go?
Quick question... after valve adjustment, oil change, plugs change, and about to change points, decided to just try starting the car... did not fire up.. just cranked... i noticed a loose wire and I have no idea where it goes. here is a pic... is it a ground? will the car run without it hooked up? looks like its a black wire. car is a carbureted 2.2 911t thanks!
Old 12-01-2013, 02:03 PM
HarryD's Avatar
Is there a spade lug on the side of the distributor that is missing a wire? This may it.
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 12-01-2013, 02:07 PM
It should connect to the distributor, it goes to the same connection as the black/purple wire.
it looks like the black wire is coming from the 3 pin Bosch CDI... wheres it plug into?
Old 12-01-2013, 02:10 PM
spade is broken off and stuck inside the female end... have to yank it and get another male spade
Old 12-01-2013, 02:11 PM
yup... i found the busted end at the end of the purple black connector. thanks everyone!
Old 12-01-2013, 02:15 PM
ROW '78 911 Targa
timmy2's Avatar
571-619441 is the part number for the correct double spade connecter from Mouser.com 13 cents each.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 12-01-2013, 05:18 PM
