dan (guest)
Guest
Posts: n/a
I have a 85 911 3.2 with intermitten starting problems. Now it will not start at all. When I turn the key to run possition should i be able to hear the fuel pump run until pressurized
This post was auto-generated based upon a question asked on our tech article page here:
Old 11-22-2013, 07:32 AM
Nick at Pelican Parts's Avatar
I would perform a fuel delivery system test. Check fuel pressure, volume and quality.
- Nick
The default answer for all the 3.2 Carreras is check the DME relay first.
If the starter is engaging and the engine it turning over but not starting the number one thing to check is the DME relay under the driver's seat.
Old 11-22-2013, 07:40 AM
pete3799's Avatar
No....fuel pump will not run with the key in the on position.....only when turned all the way and the motor is cranking.
Pete
79 911SC RoW
Old 11-22-2013, 08:42 AM
