Turbo Hooligan
D-Zug Tours RSR dyno
This morning it was around 60 degrees and misting rain, I think it may have been a more appropriate day to dyno a jag or aston rather then a Porsche, but we needed a baseline dyno before we change to our Al Kosmal licensed ITB/EFI kit. The engine specs are:
3.2 SS SC engine 9.5:1 pistons, 964 cams and SSI's/megaphones running stock CIS injection. We put down a repeatable 190hp and 184tq at the wheels.
D-Zug ![]() Last edited by pkracer21j; 03-30-2013 at 01:42 PM.. |
Holding good power, it ll be good to see what the change does
Bruce |
I'm on pins and needles here waiting for the results of the swap. I have 46mm PMO's on my new 3.4 liter twin plug and I'm having the typical carb issues. The ITB or EFI swap is coming. I just need a little push. Good results from this thread could do it.
Craig T Volvo V60 - Daily Driver (I love it!) 997 Turbo - FVD Exhaust, GIAC Tune - 542 dyno hp on 93 oct 1972 Chevy K-10 Pick-Up Truck Hugger Orange
I am "on the list" for an Al Kosmal / D-Zug ITB setup. Very excited!
Looking forward to the results! Ben. |
Senior Advisor
OOOOOOOOOOOOOOh this should be good
08 Cayenne Turbo |
Just a little sneak peek at our progress....
We're doing all the little things as we go (bracket fabrication, creating an organized and labelled wiring harness, measured hose lengths, etc etc) to make this into a true 'plug and play' kit for guys that want to go EFI-ITB in a comprehensive and relatively cost-effective fashion. As we are doing this while bringing our 930 shifter to market while concurrently keeping up with parts production, it is taking a little longer than our usual weekend or two ![]() Fire up, tuning and full installation thread soon.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com Last edited by juicersr; 06-01-2013 at 08:18 AM.. |
The ethos behind D-Zug and Al's work is right on and I am very much looking forward to running your ITB system.
Your throttle pedal is imho a great addition to my SC, and Al's grille adds a nice touch of retro-coolness to the exterior. Really enjoy both produkts! Are you planning on offering an ignition setup as well? TIA, Ben. |
No plans at the moment for ignition for the N/A kit. However, once we have this dialed in, being turbo guys at heart, we are already planning a forced induction version (935/962 style set-up) in which we will prolly have to do spark mgmt.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com |
Capitalist and Patriot
The new ITB setup, keeps the stock CIS pistons? Effectively keeping the P&Cs stock with a top end induction plug & play?
Love what you guys are doing - btw 911Freak gives this two freakish thumbs up
Former Test driver & Production Manager Singer Vehicle Design 2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold) "Dream it, Believe it, Decide it, DO it " |
Justin,
Looking good. As usual, you are doing nice work. Do you have the A/F chart recording, as well. I expect that the difference in tune-ability (optimized A/F ratio at all loads/RPMs) between carbs and EFI will be significant, but the difference between CIS and EFI, may also prove to be interesting. Although a well set up CIS system, works very well, it would be another point of comparison. regards, Al PS: I was down at the RGruppe Treffen in Solvang, CA. a couple of weeks ago (nice little 3000 mile round trip with the PNW crew) and there was quite bit of interest in the EFI work.
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
This system will primarily be an alternative to carbs using proven and reasonably priced components. For guys not savvy with carb tuning, or more comfortable with a laptop, this will provide an easier way to eliminate lean or rich spots on hotrod motors or those with unique cam/displacement combos. I suspect many guys with stock motors will probably keep being completely happy to keep their CIS systems going, but the success of the Tbitz kit has shown that, like MFI, the components of CIS are not getting any younger. At some pont, all the hair pulling to keep AAVs, WURs, fuel heads, etc in good working order for a quick starting and smooth running 911 will wear the patience of many, including yours truly. Oh, and nothing quite like the sex of appeal of ITB's sittin under you lid
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com Last edited by juicersr; 06-02-2013 at 06:16 PM.. |
Itbs
regards, Al
Still have a few wrinkles to work out before dynoing, but the ITB music she's making so far is not too shabby...
Sweet!
I just discovered this thread. Nice Guzzi as well
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk |
Justin,
oh yes! Great job. Sounds sweet. The retro-coolness of my S3-ITB/EFI system looks right at home in the DZug RSR and when you hear that monster go by....it's a good indication that it's more than eye-candy. When i watched/listened to that video, it put a big smile on my face. regards, Al
Gotta say tho, we would have already done the dyno session if we had ditched the distributor and gone straight to EDIS/Coil pack/crank trigger. We at D-Zug love old-skool as much as anyone, but deep-sixing the CIS while staying with the distributor keeps another old and potentially problematic link in the chain that can continue to give headaches. Getting and keeping a good tach signal going to MS is only one factor; clinging to the distributor obviously deprives you of the abililty to easily adjust timing when tuning, something critical for anyone tuning a hot motor as efficiently as possible. Phase 2 of the kit will be for those that wish to integrate complete spark control.
DZ12,935K3,934,2.8RSR Ducati 900ss/GhezziBrian STW dzugautomobili.com Last edited by juicersr; 07-14-2013 at 05:11 PM.. |
Thanks Jes. Still waiting for pix of either the 930 or Carrera coming down the Corkscew
Justin,
I haven't used a distributor for quite some time. I've been using Ford EDIS/Crankfire. I usually advise folks to change one system at a time though...I.E. get the fuel working well and then change the ignition to EDIS/Crankfire. But you guys know what you're doing...........ditch the dizzy. Al PS: nice work
We would have ditched from the start as well, but we figured a lot of guys will want to stick with the distributor, and thus wanted to deal with the issues these customers would encounter.
I can't just go down there. It has got to be part of an event of some sort - crap. On top of that. The Carrera 3.0 is not running for the time being. Oil press issues, see text... drive the 930 everyday though ![]() Once again, this looks awesome
Jesper Carrera 3.0 1975 930 1978 OEM Matte Schwartz, ANDIAL IC, BL WUR, SC cams. LMA-3 w. XD-16 and CP transducer www.stauningwhisky.dk Last edited by jsveb; 07-14-2013 at 09:31 PM.. |
