Tony911Z's Avatar
Ball Joint Failure...Don't Ignore the Squeak
My SC's front end had been squeaking for a couple of months and would subside after I sprayed white lithium grease around suspension joints. I thought I had a bushing issue until my ball joint failed completely, luckily at low speeds.
Tony Z
'78 SC, '03 Boxster S
Black Forest, CO
Old 11-27-2013, 07:43 AM
KNS KNS is offline
Wow, good thing you weren't taking a corner at 50 mph. How many miles?
Kurt
Old 11-27-2013, 07:50 AM
Charles Freeborn's Avatar
Yep, got your money's worth out of that one...
Bone stock 1974 911S Targa.
1972 914/4 Race Car
Old 11-27-2013, 07:54 AM
Retired, finally
SiberianDVM's Avatar
Ouch!
I'm right in the middle of a suspension upgrade on my track car: 235,000 mile 84 Targa. So far, every joint, bushing, and bearing that i have replaced has been solid and fully functional. Shocks were a bit worn, though.
2009 Porsche Cayenne Turbo S; 2019 Corvette Grand Sport Coupe; 1998 Porsche Boxster; 1989 Toyota Supra ChumpCar; 1989 Alfa Romeo Spider; 1977 Porsche 911S Targa 3.2L"Bwunhilde II" chimera; 1970 Datsun 240Z 2.9L "dogZilla" project
Old 11-27-2013, 08:09 AM
Under the radar
Trackrash's Avatar
Wow, count your blessings you weren't going that fast. I finally replaced my 40 year old ball joints a couple of years ago, even though they seemed fine. Glad I did after seeing this.
Squeeking on the front is usually caused by worn A arm bushings causing the torsion bar to rub. You might want to consider a complete suspension refresh.
Gordon
'71 911 Coupe 3,0L outlawed
Old 11-27-2013, 09:36 AM
weekend wOrrier
This happened to me about 20 years ago. It never squeaked, but the steering did become noticeably stiffer days before the joint failed as the ball was working it's way out. This was on a 1966 suspension. Glad you are okay. I was going slow too and was near the house. I walked home, got some tools, removed the wheel, propped the suspension on an old skateboard, and drove the car home very slowly on the skateboard. Although I was super proud of my macgyverness, it's one of those butt puckering "what-if" scenarios "if only I had been going faster", etc...
Ron
Old 11-27-2013, 10:27 AM
Weseeeee911
I just started hearing a squeak in my front end. Thanks for the tip!
Al
80SC 95-present
Old 11-27-2013, 11:40 AM
AutoBahned
RWebb's Avatar
I lube the ball joints every few years. Obviously a critical safety component.
Old 11-27-2013, 01:16 PM
How do you do that?
Old 11-27-2013, 08:55 PM
tazzieman's Avatar
Originally Posted by Eagledriver View Post
How do you do that?
Use a sonic screwdriver.
'81 924 , '85 944 , '78 911SC , '82 928 5.0L
"They run best being run close to the ‘limit’ and done so regularly" - Grady
Old 11-27-2013, 08:59 PM
AutoBahned
RWebb's Avatar
Like this:
Yet Another Boring Rgruppe Car – Part II, Suspension
Old 11-27-2013, 09:22 PM
