Nobody
bob tilton's Avatar
Post different keys???
so i figure it's time to address my ignition/door key situation.
non-original ignition key has the following info stamped on it:
-taylor USA, P79Bm measures 2 1/8" in height, works fine.
-non-original door key: ilco DM4, 1 7/8" in height, opens driver door, does not open pass door but can be inserted without turning.
-door handles are correct for the year.
i have read over the pelican article and suspect i will need to run thru the tumblers for the pass side.
i question why i have two different style keys as i thought i should have ONE key that fits all, correct? if so which key is incorrect? where do i get replacement keys? i've only seen blanks avail for '69+. even if i re-do the tumbler pins i would still have 2 different keys. what's the deal?
tia,
bob
Old 08-31-2001, 09:17 PM
Post
What year is it?
Old 08-31-2001, 09:24 PM
Nobody
bob tilton's Avatar
Post
sorry, i edited that info out by accident. it's a '68 911L.
Old 08-31-2001, 09:37 PM
Post
Im stumped!! Maybe the small key is a valet key (Just a thought). We need others to post some opinions. I cant figure it out....TargaEuro
Old 08-31-2001, 10:03 PM
Post
Your ignition uses the 70 on style key, while your driver's door lock uses the standard, though NLA/hard to find NOS, early style key.
I have blanks, Taylors & Ilco's, if you need them.
Scott
69 912 #23078
68 912 sunroof
67 912 project
Old 08-31-2001, 10:29 PM
Post
Oh - and I'm sure you caught this already but your drivers and passenger locks are different (same early 65-69 style, but different tumbler patterns = different keys). The PO may have replaced one of the handles and lock assemblies. You can have a key made for the passenger's side pretty easily - even though that doesn't save weight on your key ring. Good Luck - Scott
Old 08-31-2001, 10:34 PM
Post
I went thru this key blank hassle a while back. I work in a hardware store and checked several suppliers for the correct blank, with limited success. The blank that came with the car is a Taylor P79B and works pretty well. I had the door handles apart and noticed this key wasn't getting the tumbler pins quite flush with the tumbler. I found that Ilco still makes a P79B blank, so I ordered a bag. They were too thick and needed to be filed down to fit into the lock. I did this and reworked the height of the sections of the key that raise the pins. The key works great. I am now planning to spend the big bucks for a genuine blank or two to make a good copy.
Scott, do you notice the Ilcos being too thick for the keyway, and are the Taylors any different? If you have a couple blanks that are a good fit, I would be interested in them.
Ron
69 911E
Old 09-04-2001, 02:06 AM
Thumbs up
call STODDARD
RoninLB
Old 09-04-2001, 02:20 AM
Post
Hey Bob
http://www.jaggraveyard.com/keyquest.htm
For keys for old Porsches, I just bought a couple for my 1968, they have pictures that allow you to check the size and if you e-mail they will measure things for you so you get the right key.
Robert
Old 09-04-2001, 04:08 PM
stormcrow's Avatar
Post
I went down to the local Ace Hardware store and had a couple made from the original. Have two sets of keys. One opens all doors and locks. One works just the ignition and door lock - used for valet parking.
Old 09-04-2001, 06:38 PM
Nobody
bob tilton's Avatar
Post
thanks everyone, i bought several key blanks from scott (ck's in the mail). he sells them at a very realistic price. again, thanks for the info.
bob
Old 09-04-2001, 08:23 PM
