Msd tach adapter
Hello everyone. I've been reading this forum for several years and really didn't have much to add till now. Or rather anything to ask. I have a 76 turbo. To make a long story short the coil went bad, age I guess, fried the CDI unit. So doing a little research I went with the MSD6AL. Naturally the tach didn't work so I ordered the tach adapter which may be the wrong one. It is 8910EIS. The wires it has are a red, black, and 2 greens that go into a plug. Is this the wrong adapter or can I make this one work? This is driving me nuts.
Old 08-30-2002, 12:39 PM
I have a 75 turbo with the MSD6-al in an 81 SC. My tach works without the tach adp. Are you sure it is hooked up right?
Dean
911 SC turbo, 3.0L 930 motor, G50, 930 brakes, DTA EFI, 352 RWHP DynoDynamic dyno,
Old 08-30-2002, 12:42 PM
I went into the archives and from what I gathered it depends on the year car you have as to whether you need an adaptor or not. I'd bet my old 76 has a different ignition system or tach than your 81. I did find an article describing how to wire it up. That thread talked about a red, a black, a white, and a violet wire which the 8910EIS does not have. Anyone have any ideas?
Old 08-30-2002, 12:51 PM
I think I hooked up the old wire from the tach to the spot on the MSD box and it worked. Do you have said tach wire? Did your old cd box have 6 wires?
Dean
Old 08-30-2002, 01:14 PM
FWIW, a 1980 911SC needs no adapter.
Eric Purdy
Old 08-30-2002, 02:03 PM
