geoz's Avatar
How to install gauges
I have pulled out all my gauges to install LEDs. I'm really happy with the way they look, they are much brighter now.
Now I got to put them back; not a big issue for the smaller ones, but I find it really hard to get the bigger ones to seat properly, and for the rubber ring not to get pushed up too high.
Is there a trick? Can I use some sort of lubricant? I was thinking hand creme, any better ideas?
cheers
hg
1988 911 Cabrio
Old 12-06-2013, 12:49 PM
86FlatSix
JQ911's Avatar
I recall when I replaced the dashboard of my 86, I used WD40 (sprayed a little) on the rubber ribbed rings and it went in easily. However, a lot here do not recommend WD40 so any lubricant will do (vaseline or KY).
74 BMW 2002 (rust rocket)
86 911 Coupe (weekend warrior)
09 997.2 C2 (semi-daily)
Old 12-06-2013, 01:09 PM
emac's Avatar
Man you guys are getting sick---lol
Ernie 81 SC
Old 12-06-2013, 01:18 PM
sky1jord's Avatar
Liquid hand soap
Old 12-06-2013, 01:21 PM
I use Armor-all or a similar protectant. Works great. Try not to use WD40 on rubber, as the petroleum basis can break down certain rubber compounds. Best is silicone base.
Old 12-06-2013, 01:26 PM
86FlatSix
JQ911's Avatar
Ok..ok.. I stand corrected...Use KY or vaseline in more important stuff
Old 12-06-2013, 01:34 PM
+1 on Armor-all. Put the rubber ring in its spot and use a cotton ball or paper towel to coat the ring surface where it will meet the gauge housing. Worked great and keeps the rubber pliable. Easy clean up.
Old 12-06-2013, 01:41 PM
