Possible Transmission Failure
Tried to take my 1981 911SC out for a drive this morning and pulled out of my driveway and all of a sudden I heard a clunk clunk then none of the gears worked. When I try to engage the gears I hear a metallic rattling coming from the rear of the car. How bad is this?:mad::mad::mad:
Today is your lucky day. Sounds like a CV let loose. Good thing it was in your driveway and not on the freeway.
So what now? I sounds more ominous that a CV joint!?!?
Sure sounds like a CV to me too.
Jack the back end up and see if one of the axles is disconnected.
Metallic rattling noise associated to transmission could be very bad news. Did you launch out of the driveway, did you miss a gear.
Axle C/v joint.
I backed out of the garage as I normally do; all gears were functioning, then when I went to drive down the road from reverse to first there was no response. I cycled through the rest of the gears to see f I could get a response and all I heard was this rattling sound!
I will put her back in the garage and check put the CVs as recommended. Thanks |
You guys are geniuses. I got the car back into the garage and sure enough the left rear CV bolts have backed out. is it as simple as screwing them back in to fix the problem?
For now, I would think so. Re-tighten the bolts on the other flanges also.
The bolts that became separated have been beat up a bit so best replace them in the fairly short term depending on how much you plan on driving this winter. If a bolt is not straight, don't force it in. That's just thoughts from a drive train layman. |
I had a chance to take a closer look at the situation and what I found is all flange bolts on the wheel side have backed out completely so that the entire assembly is detached from the wheel. As I go in to re-attach the joint to the wheel is there some kind of way to get the joint aligned to the wheel so that I can screw the bolts in?
not sure what you mean, as you just turn the wheel/axle and line them up
but, first STOP take each bolt out and inspect it carefully - use a magnifier if you have to look at the threads to make sure they are in good shape & the wrenching fixture in the head then go buy some brake cleaner and clean the threads on each cap screw of all oil, grease etc. also clean the female threads inside the thing the cap screws go into - use Q-tips with brake cleaner on them & clean until the Q-tips shows NO grease after cleaning you will do this while you are waiting for new Schnorr washers to arrive as they must be replaced each time search on Schnorr for more info use a good torque wrench whose calibration you have checked |
you might also look at the surfaces that come together and stone down any burrs that got kicked up as things came apart, this will help get things solidly reattached
Looks like things wont be quite as simple as cleaning thigs up and replacing washers before re-assembling.
I took all of the bolts out and inspected them and discovered one has been broken off so I am going to have to remove the broken piece from the part that it is screwed into. Does anyone have any ideas on how to go about doing this and does anyone have a exploded diagram of the assembly so I can see what I am working with. I looked at the parts diagram online but don't see the piece that the broken bolt is screwed into. Thanks in advance! |
If the bolt is broken off then the tension is gone it should just back out with your fingers or pliers if necessary.
It will be a messy job but shouldn't be that difficult. I had a bolt break off (over-torqued) and was able to back it out with pliers.
You will probably want to clean the joint that is open and re-pack it with grease. If any grit got in the grease, you will have a CV joint failure before long and then you will have to take the whole thing out, which is an even bigger and messy job. That was last summer for me! |
The "Reconstructing...." thread porwolf posted is a good one.
The 81 (non-turbo) has 8mm bolts, no washers, no moonplates from factory. I don't believe you can buy these parts (washers/plates) from Pelican so you have to source outside. The threads will give you direction. Take your time. On the bright side, your trans is ok, right? |
I suspect the trans is OK. The Joint on the trans side is intact. There is nothing for me to grab onto with pliers on the bolt-head side, is it possible that I could have something to grab onto on the wheel side?
Aren't you glad this happened a car length away from home?
This makes the idea of checking the car on a regular basis a good idea. If you find something loose or broken...it's always cheaper and faster to repair it at home (your tools and sweat) than it is to have the car towed to some place that will probably over-charge you for a less than superior job. No ill feeling towards repair facilities...but I like to rely on my eyes, hands, and brain for repairs (I'm cheap...LOL). Bob |
diagrams are in the PET, go to Porsche's web site for them - parts diagram
if not recessed: see if you can grab it hard with vice-grips and turn it out if recessed: go buy a left-hand drill bit to get the broken bolt out - if lucky you will not need to drill it all the way out and the LH force will encourage it to come out |
Hey guys here is a pic of what I am dealing with. The white arrow points to the sheared off bolt that needs to be removed. At this point I plan to use an extraction tool unless there is another way to do this.https://www.dropbox.com/s/lp46csoksn...3475247http://
https://www.dropbox.com/s/lp46csoksn5i9ku/Presentation1.jpg?n=73475247 |
Really glad it happened close to home. It gives my wife one less reason to tell me to get rid of the car.
I finally got around to pulling the axle so I could get to the broke bolt. after I dropped the axle a couple of the bearings dropped out- is this normal? I am now soaking the assembly in cleaner so I can repack it with grease before re-installing. |
Check the bearing contact areas for any signs of pitting or galling.
I extracted the broken bolt and cleaned everything up. I decided to replace both CVs - awaiting parts from our sponsor.
Cannot emphasize how lucky you are on this. You'd be weeping over a cracked transmission case when the axle self-destructed and whipped around at speed, worst case.
Drama aside, you cannot get away from a very careful analysis and recon. of the issue. Buying new bearings is wise I think for a 130K and up car, esp. on the drive side. But I'd check the other (left) side - did you mention mileage? - to be sure nothing is going to act up over there. You might get away with carb cleaner and Q-tips and a very good fitting allen socket for that side. I had to helicoil one or two of the threads on the trans-side flange and plan on finding a good used one to install - I rebuilt mine with new bearings and am very happy. Do be certain to browse the links provided in this post. This is a good thing - messy but peace of mind fix for certain. Check you door stops next :p |
Jdub, thanks for the insight! The car has 86K original miles! Everything is all cleaned and just waiting for the new parts. I will report how the reconstruction goes. Next on the list of things to do is track down a bloody oil leak!!
Replacing CVs and greasing them up is a dirty, smelly nasty job.
PMB Performance is a Pelican vendor. Consider a set of prebuilt axles......swap them in. You'll thank me. BTDT. |
Joe Bob:
Thanks for the info. |
All parts are in and I am rebuilding the shaft. Two questions:
There is a groove around the new bearing, does it matter how it goes back on the axle? How does the concave washer go back onto the shaft? if it goes on concave side against bearing i do nor have enough room on the axle to fit the circlip? |
CV bearings have been replaced and the car runs like a champ again. Thanks all for the support!
Make sure that after 100mi or so you get back under there and make sure they are all still properly torqued down.
Will do. While under their I checked the torque on the left side and everything was sound.
| All times are GMT -8. The time now is 11:16 PM. |
