Hi all, I got the above after searching the site. Thanks Keuhl. My question is, do you have to completely remove bolts/nuts 1,2 and 3. With mine I think I may have to in order to fit my fanbelt back on because I can't slide the compressor close enough to put the belt back on. Any tips?
Johann 1986 911 Carrera [SOLD] 1980 911SC [SOLD] 2004 911 |
You should be able to slip a new belt on by just loosening the three bolts and loosening the adjuster bolt all the way. What size belt are you using? Try a longer belt.
Pete 79 911SC RoW "Tornadoes come out of frikkin nowhere. One minute everything is all sunshine and puppies the next thing you know you've got flying cows".- Stomachmonkey |
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Belt change.
The correct P/N for our '86 is:
999-192-176-50 Fan Belt 9.5 x 710 mm. Here are pics from the PET: ![]()
1986 911 Targa. Per Road and Track magazine: Only in L.A.: In the window of a bar in Hermosa Beach, California. "Happy Hour prices during all car chases." |
Johann,
Assuming you have an SC with stock York, the belt size is usually a 13x1100, original pn 900 192 027 50. Loosen 13mm head bolts 1,2,3. Loosen 13mm head nut 4 so the slider plate moves all the way to the left. If the belt won't come off the pulley you then remove bolts 1 through 3, tilt the compressor with its slider plate toward the left, slip off the belt. |
i have to remove all three and tilt the compressor
Jason 81 SC 97 328is 87 Jeep Comanche (RIP) |
Hmm, that's what I suspected. Okay, thanks guys. Will give that a crack.
A/C Belt.
Gerry Cheers......
Sorted! Removed all three and the belt went in to place with a bit of jiggling! NVH levels have improved from an in cabin perspective too! thanks all.
The air "conditioning" part - not so much! lol. So everything seems to be operational. What's the best bang for buck improvement other than a potential regass? My last regass was probably february last year. how long should it last? I was thinking a new evaporator? mines pretty banged up. at the risk of starting WW3..........
