How do I undo these?
I'm trying to remove the front dash panels. I can't get these undone.
I would assume they in screw, but I could be wrong or the previous owner glued them. I also can't get the cover off around the ignition key?
All unscrew. On the black ones, I use two small screwdrivers that fit in the holes and a larger one to twist between the 2 to unscrew them.
The lighter unscrews from the back. Hold the front part and reach in through the clock hole to do it. The ignition surround also unscrews. |
Thanks 😃.
The ignition one just won't move. |
The panel themselves are glues on and care should be taken when taking them off otherwise will rip... A sharpened putty knife works well.
Alex ____________________ 1977 Porsche 911S (Daily driver) 1972 Porsche 914-6 GT Clone (Project) |
Take off wire and turn the swicth and it will loose goes by the clock hole like group 911 said .
