leverpuller's Avatar
Fan won't fit without schiming. Help?
Hi all, my problem is somehow after cleaning, light sanding,and light buffing the fan shroud, on my work bench, I reinstall the alt. and the fan (still on the bench)and the fan is not even close to fitting without touching the housing. In my zeal to clean, did I scrape away to much dirt or something? After hours of angry trial and error I finally fit the fan without it hitting anywhere by making a schim to fit between the alt and the housing. Am I missing something here? After all it's the same alt and same housing. Any help would be appreciated .
Old 12-21-2013, 06:32 AM
non-whiner
mreid's Avatar
Pictures please! This is a precision fit and usually when this happens it is an install/missing part issue.
"Too much is just enough."
Old 12-21-2013, 06:41 AM
kodioneill's Avatar
Do you have the washer between the fan and alternator facing the correct way?
1974 sahara beige 911 targa
1982 chiffon 911sc
1985 prussian blue metallic carrera
Old 12-21-2013, 07:04 AM
Yeah the washer was intack but there's nothing on the housing itself that I removed while cleaning and polishing ? I even cleaned the mounting flange with the six threaded holes. Weird.....
Old 12-21-2013, 07:15 AM
kodioneill's Avatar
Intact ok but is it facing the correct way? There's a shoulder on the washer.
1982 chiffon 911sc
Old 12-21-2013, 07:21 AM
I'll check later I just got called to go to work thanks
Old 12-21-2013, 07:42 AM
Ps the reason I had the thing apart was to see if the brushes were bad because the last time my tach started bouncing all over the place, the mechanic replaced the alt. now 15 years and 60000 mi later it did it again. But the brushes looked find some wear on the armerture or rotor but not bad.but to test the alt I have to put it back and drive to the shop so I might as well get a new one
Old 12-21-2013, 07:51 AM
wwest's Avatar
Take a good look at the stator winding insulated supports, the insulation on mine were long sense burned away and thus I got intermittent stator phase shorting on bumpy roadbed.
Old 12-21-2013, 09:22 AM
Sometimes if the fan is hitting the side you need to torque down on the alternator bolts holding into the housing. Tighten half of them and find the balance point that the fan isnt hitting.
Sometime you have to remove and spin in the housing but seating is the problem and response.
Bruce
Old 12-21-2013, 09:31 AM
Band.
I agree that MOST of the time the problem is with the way the ALT is seated into the housing, not a problem with the fan on the shaft of the ALT.
Make sure the ALT is seated properly in the housing and then the fan should fit much easier.
1983 SC Coupe
1963 BMW R60/2
1972 Triumph Tiger
1995 Triumph Daytona SuperIII
Old 12-21-2013, 11:58 AM
I'm back and thanks for replying guys. We'll I broke everything down . What I see is the shoulder ( wider flange) was toward the bearing is this correct?
Old 12-21-2013, 01:23 PM
Old 12-21-2013, 01:26 PM
A pic of the schim in place
Old 12-21-2013, 01:32 PM
clarkd's Avatar
I believe the washer needs to be flipped from how it is in your photo. The raised step needs to mate up with the inner race of the bearing.
Old 12-21-2013, 01:45 PM
Ok thanks , because I've looked in my books and nothing. I'll let you know.
Old 12-21-2013, 01:48 PM
flip the shim but you still need to seat properly in the housing.
Bruce
Old 12-21-2013, 04:13 PM
nothing to do with the washer or the shims. the bottom of the housing looks crusty which will cock the alternator.
206 637 4071
Old 12-21-2013, 04:37 PM
Taking it apart is easy
Jerome74911S's Avatar
All of the above?
Jerome
PLEASE CHECK MY QUIZZICAL BLOG: www.ponderingporsches.blogspot.com
Old 12-21-2013, 05:37 PM
Thanks for the tips. I should have left the thing dirty. Though.....lol!
Old 12-21-2013, 06:05 PM
Now that everything is back together, I'm still experiencing the fluctuating tach needle. I tested the voltage and at 2k rpms I got 14.05 volts. I have an optima red that's about 5 years old to which I have not tested yet if it is the voltage reg will I have to get a new alt. or just the regulator
Old 12-22-2013, 10:08 PM
