Fuchs with spacer or not and does it look right.
I got this 28mm spacers on rears.
![]() I did belive it was because cant fit my Fuchs copies or wrong model for my 911SC -83 narrow.But tried today when had too adjust handbrake and wheels does fit fine.Mabey the are right Fuchs for my 911 ![]() But now looking at center hole. ![]() shouldn't big hub lips match against wheel lips if it is original type? Sorry if quest has been upp before but could not find when I did search here.
911 SC -83 Coupe |
Hi
Those should have an ET/offset of 23,3 and would probably fit better up front. They were manufactured between 1977 and 1984. How wide are the Fuchs you have up front? /Johan
SEARCHING FOR ENGINE 6208326 (last seen in car with VIN 9111101452) 911E Coupe -70 Carrera 3,2 -84 Sold |
Hub bore should be a snug fit with the hub. Looks like you need a hub-centric spacer. they are available from many sources. You need to specify inside diameter and outside diameter (i.d. and o.d.) and have them custom made.
What's odd is that the hub appears too small since you're showing part numbers of a stock Fuchs. But it's confusing because you mentioned Fuchs replicas...
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher Last edited by techweenie; 12-21-2013 at 09:46 AM.. |
911 SC -83 Coupe Last edited by mv70; 12-22-2013 at 12:49 PM.. |
