teardrop's Avatar
Which lubricants to use when refitting o-rings/grommets ect...
Before replacing my cylinder head temperature sensor I read several posts that recommended Vaseline for lubricating the grommets before refitting them.
I thought that Vaseline was not water based and can attack rubber so I used KY Jelly instead which is water based and supposedly safe on rubber (good job considering its intended use).
I am refitting my injectors soon (89 3.2) and have been advised to lubricate the o-rings so they go in more easily. As these are a little more important than the grommets I thought I'd solicit opinions on what others would use and what is safe/unsafe to use on rubber components, especially the o-rings.
Cheers
Andy
Old 08-27-2002, 10:31 AM
Friend of Warren
I use Dow111 silicon lubricant
Kurt V
Old 08-27-2002, 10:55 AM
wet style silicone spray on the temp sensor grommets, and just a light coat of dow 111 silicone paste on the injector o rings.
206 637 4071
Old 08-27-2002, 10:56 AM
