Help me identify this
Can you guys help me identify this engine
Here are the numbers the seller can find Engine case numbers 901.101.102.2R and 901.101.102.3R Zenith carbs picture below shows the engine any help appreciated
You need the engine numbers they're located right side of fan housing on the case near the oil temp sender.
1974 sahara beige 911 targa 1982 chiffon 911sc 1985 prussian blue metallic carrera |
working on that with the seller, told him that already.
The case number range and the Zeniths allow you to narrow it down to 2.2 T with a degree of confidence. The stamped number will tell all.
techweenie | techweenie.com Marketing Consultant (expensive!) 1969 coupe hot rod 2016 Tesla Model S dd/parts fetcher |
Engine number will tell but it fun to guess by distributor 71E
