Southern Class & Sass
Dixie's Avatar
I can see slearly now.
Finished installing my new windshield today. All the threads on this forum ensured the project was a success. My biggest challenge was getting the old moldings into the new seal. They finally went together once I liberally doused everything with oodles of silicone. I also found roping the moldings in with a 22 gauge wire helped.
Dixie
Bradenton, FL
2013 Camaro ZL1
Old 12-28-2013, 03:27 PM
Chain fence eating turbo
It's not a relaxing project. Actually, quite stressful.
Old 12-28-2013, 07:11 PM
Capt - I've heard horror stories about using silicon spray lube and windows popping out. No personal experience. I used dish soap on a windshield I did many years ago. Also heard watersoluble surgilube works well. BTW - I'm down the road in Sumter if you need a hand with your next one.
Bryan
Old 01-05-2014, 05:48 PM
redridge's Avatar
+1 on watered down soap, even window cleaner... when the dry, they get tacky and sticky. This helps the molding stay put.
Old 01-05-2014, 05:57 PM
Caveman Hammer Mechanic
ClickClickBoom's Avatar
I used actual rubber tire lube, used for mounting tires. Says lubricates and after it dries acts as an adhesive.
1984 Carrera El Chupacabra
1974 Toyota FJ40 Turbo Diesel
"Easy, easy, this car is just the right amount of chitty"
"America is all about speed. Hot,nasty, bad ass speed."
Eleanor Roosevelt, 1936
Old 01-05-2014, 08:36 PM
Silicone makes rubber swell.
Bruce
Old 01-06-2014, 04:37 AM
