Longhoods Unite!
PhatRedHead's Avatar
Send a message via AIM to PhatRedHead Send a message via Yahoo to PhatRedHead
Alternative heat for defrost
Been looking into a small electric heater that I can incorporate into the front plenum to be able turn on just to use as a defroster of the front screen. Heater tubes from the rear are gone, want something low power consumption and small in size.
Anyone done anything like this?
Thanks,
Joe
1970 911T -- Neglected, oil burning problem, batman smoke
1974 914 2.0 Weber'd -- new project!!
**My Wife and I bought our first house in August of 2009, the footprint of the house is just over 1100 sq. ft...my garage is just over 1000 sq. ft. We compromise well **
Old 04-18-2014, 07:17 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
With any electrical heating coil...the current/voltage determines the BTU's of the unit.
So...if you wanted a 750 Watt heater (approx 1 HP) witha 12V system you would need to feed it with 62.5 amps
This is a huge amount of current for the alt and system to supply....and probably why Detroit and the rest of the auto industry do not use electrical heaters in this application.
Perhaps an alternative is to bleed off some heat from the oil cooling system...if you have a front cooler...maybe a hose or channel from the output of the cooler to the defrosters might work.
Good Luck
Bob
Bob Hutson
Old 04-18-2014, 10:21 AM
quite a few folks have put a gas heater (Webasto) into the smuggler box. The other solution available is a heated wind shield, I have seen more than one sources already.
Old 04-18-2014, 10:34 AM
esonefour's Avatar
A friend of mine has fitted a 12v hair dryer to a 911 race car, Will be looking to do the same this winter.
Not to sure on amps and current draw etc .
Old 04-18-2014, 10:38 AM
porsche4me's Avatar
Ceramic Heater, 12V, 200W - $24.79
used one in a 914 that had headers ---- loved it --- in south fla in the hard winter... lol
1977 911S Coupe
Stolen - car chase - in the river - pulled out - sold to me!!!!!
"Life is running hurdles in the dark"
Old 04-19-2014, 05:38 AM
Senior Member
Jdub's Avatar
I typically use a rag with an MG moniker on it (deadpan...).
'78 Targa in Minerva Blue
Old 04-19-2014, 11:27 AM
porschetub's Avatar
A very sucessful Targa Tasmania Porsche driver Rex Broadbent uses a 12v hairdryer in his 911,works a treat from what he said in an article on the car.
I will be going this way with my 914/6 conversion.
1985 944 2.7 motor,1989 VW Corrado 16v,57 project plastic speedster t4 power,1992 mk3 Golf,2005 a4 b7 qt avant 3.0 tdi,1987 mk2 Golf GTI,1973 914,2.2t to go in.
Past cars, 17 aircooled VW's and lots of BMW's
KP 13/3/1959-21/11/2014 RIP my best friend.
Old 04-19-2014, 01:26 PM
