toddu's Avatar
Rear fuse block picture request
Anyone have a picture for the rear fuse block on a 911SC? Mine seems to be missing a few things and I'm curious about the wires on the left side.
Todd
'81 SC
Old 12-30-2013, 07:02 PM
Heck, I’m only 5 not 71!
targa80's Avatar
This is a pic of the engine compartment of my 1980SC, the fuse panel is visible.
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 01-01-2014, 09:24 PM
toddu's Avatar
Hmm, it seems like in each pic I see the wires on the left are in different positions. I'm not sure what the difference between thick and thin wire is. Hot vs switched?
Todd
'81 SC
Old 01-02-2014, 05:14 AM
El Duderino
tirwin's Avatar
From my '83. Ignore the fused wire going to the wideband O2 module.
Old 01-02-2014, 06:07 AM
bodmin's Avatar
'89 Carrera.
Old 01-02-2014, 06:13 AM
toddu's Avatar
So, I think on the SC the top 2 fuses are bridged on the back side. I guess that's why sometimes the thick wire is in the top spot, sometimes in the middle spot, guess it wouldn't matter.
Mine had thick wire in lowest and thin wire in the middle with no fuse in the middle :-(
Fixing it today (and hopefully putting my new 3.2SS in!!!).
Todd
p.s. - when tapping into rear fuse for switched power, wouldn't you want to tap onto right side, after the fuse? Left is the "source" side?
'81 SC
Old 01-02-2014, 06:36 AM
El Duderino
tirwin's Avatar
Yes the top 2 are bridged on the left side. I tried tapping on the right side but the left side is only switched all the time. I think the top two on the left are constant hot and bottom is switched IIRC. I can't remember what is on the right side (heater fan relay?) but it was clearly not switched all the time.
Old 01-02-2014, 06:49 AM
El Duderino
tirwin's Avatar
Just food for thought... another "while you're in there"... might be a good time to replace the old fuse panel with one of Fred Cook's ATO fuse panels.
Good luck with the install!
Old 01-02-2014, 06:54 AM
