porsche4me's Avatar
Airbox clearance for throttle rod
Hello - Please tell me what you think if there is enough room for throttle rod .
Started my Bitz EFI install this week - Bought a custom stainless steel airbox - that may have a small tube in the way of the throttle rod .
right now the airbox and runners are just set in there not bolted down but the TB seems to be a little farther away from the firewall than stock location - as the throttle is 1/2 open just sitting there after i snapped the rod on there.
that may not be a good thing - as the rod looks like it has the ends pretty much spun out toward the ends of the rod already.
1977 911S Coupe
Stolen - car chase - in the river - pulled out - sold to me!!!!!
"Life is running hurdles in the dark"
Old 05-13-2014, 05:28 PM
Member 911 Anonymous
DRACO A5OG's Avatar
think there is a bend as I recall. You need a helper to press the pedal inside to see the travel both ways and also that it is not binding or not fully opening the throttle or too short as not to hit the idle switch if a 3.2
'85 Carrera Targa
PCA/POC
Old 05-13-2014, 07:27 PM
porsche4me's Avatar
thanks for the info - I will get a helper tomorrow to test full travel - it is a 3.0 liter and i dont think I need the idle switch after i put in the BITZ kit EFI DO I ????
1977 911S Coupe
Old 05-13-2014, 08:30 PM
ROW '78 911 Targa
timmy2's Avatar
I had to shorten the rod when installing my Webb industries stainless airbox on my CIS system.
The throttle body sits a little lower than factory.
I just ran a metric tap down further on the rod on one end and cut off the excess.
I bought a spare linkage rod with ends in the classifieds in case I wanted to go back to a plastic airbox.
Good thing I did as I ended up using a plastic airbox cut down for the clean look when I installed the Bitz kit.
Dennis
Euro 1978 SC Targa, SSI's, Dansk 2/1, PMO ITBs, Electric A/C
Need a New Wiring Harness? PM or e-mail me. Search for "harnesses" in the classifieds.
Old 05-13-2014, 11:13 PM
The throttle switch does nothing with the Bitz kit. Nice airbox. You should be able to source threaded rod if the linkage ends up short.
Kinsley
1980 SC Targa - MS2, EDIS
Old 05-14-2014, 03:54 AM
83 911 Production Cab #10
JJ 911SC's Avatar
While in there, you might want to replace the Throttle Rod Coupler (Slop Buster) just outside the tunnel. Part # 911-423-081-02-M260 1983 Porsche 911 SC Convertible - Fuel System - Page 5
I just went trough a Pedal Cluster refurbishing, fixing the crank at the pedal and replacing the Coupler. Well worth the effort, now there is no loose in the linkage and I got full deflection.
In my case even thought I got 2 return springs on the PMO butterflies, I still need to put an extra spring (at the transmission bell crank) to get a full return when I take my foot of the pedal.
You might want to look at this thread Throttle Linkage Adjusment, where Wayne (oh Haha): post a link on the adjustment of the linkages.
Who Will Live... Will See
Old 05-14-2014, 04:55 AM
