non-whiner
mreid's Avatar
RSR Interior Conversion
I'm now moving to the inside on my 74 hotrod RSR IROC-ish. Have to get rid of the burgundy interior. The dash, knee pads, and door panels are in excellent condition, but just don't go with the basic black I'm looking to create. Here is how it looked as purchased:
While the cracked windshield was out, I swapped the dash and knee pads. I also installed the dash mounted cutoff switch, clock and radio block off plates, swapped the door panels, and started removing the carpet:
After Christmas, seats and rest of the carpet come out to make room for the RS carpet set, roll bar, and vintage seats.
Then of course, drop the 2.7 and 915 (sold), finish assembling the 3.6 and rebuilt 915 LSD, install it, finish and paint the wing. A maniac's work is never done!
Old 12-23-2013, 03:20 PM
Not to nitpick, but just noticed the other day that Rennline sells a new floor board mount for the passenger side.
Otherwise LOVE the direction this is headed. Looking forward to seeing the final result.
http://www.rennline.com/Rennline-Stainless-steel-floor-board-hold-down-bracket-Porsche/productinfo/F40/
1982 911 Targa, 3.0L ROW with Webers
Old 12-23-2013, 03:31 PM
redridge's Avatar
Looks good... If you want to sell any of your burgundy interior, PM me. thanks...
Old 12-23-2013, 04:12 PM
LOVE IT! I'm planning a similar transformation. That steering wheel was the worst! :-0
Old 12-23-2013, 04:55 PM
Reiver
Reiver's Avatar
Much better imo....looks good.
Old 12-23-2013, 05:22 PM
Uncertifiable!!!
Uwon's Avatar
Sub'd. Looking forward to the next chapter.
🇨🇦 The True North Strong and Free 🇨🇦
Living well is life's best revenge- George Herbert (1593-1633)
2006 C2S, 2024 WRX GT, 911 hot rods on Pelican….
Evolution of a Carrera RST, and Sweet Transplant
Old 12-24-2013, 08:07 AM
Banned
Where did you buy that early dash with the speaker insert?
And did it fit without any drama?
Old 12-24-2013, 10:05 AM
non-whiner
mreid's Avatar
I bought both in the classifieds here a few months ago. One minor crack in the usual spot in the dash pad that I will fill at some point. One blemish in the grill, but covered by the cutoff switch. This was the original style dash pad that should have been in the car. A PO cut a big hole in the metal dash for the center vent of the later model burgundy dash pad. Fortunately, it is completely covered by the dash pad.
"Too much is just enough."
Old 12-24-2013, 10:16 AM
non-whiner
mreid's Avatar
Received my other two gauges today and finished the dash. The seats and the rest of the carpet are coming out soon and the RSR carpet, vintage seats, rollbar, and harnesses going in. Can't wait!
Old 12-27-2013, 05:57 PM
non-whiner
mreid's Avatar
Victory!
Just need to clean out the glue and the RS carpet can go in. Also need to bang out a couple of dents in the floor where it appears some PO applied a poorly positioned jack. Anyone need any 87 interior panels or carpet?
Old 12-28-2013, 10:11 AM
burgundy interior
would love to have your carpets david.avrahami@bell.net....thanks
Old 12-28-2013, 10:41 AM
Your pace is amazing, what are putting under the carpet?
Old 12-28-2013, 01:16 PM
non-whiner
mreid's Avatar
Light weight padding. I need something for basic sound deadening and so the carpet goes in smoothly. Any suggestions?
Old 12-29-2013, 06:51 AM
Weseeeee911
Looking good! What are you going to do for seats?
Al
80SC 95-present
Old 12-29-2013, 07:32 AM
Originally Posted by mreid View Post
Victory!
Congrat's... the easy part is now over. Getting all of the glue out is a royal pain. Best thing I've found for it is a citrus-based paint stripper. Keep an eye on it and remove it after the glue is soft and before it does anything to the paint.
JR
Old 12-29-2013, 07:46 AM
non-whiner
mreid's Avatar
Thanks, I'll try the citrus based. I have citrus based adhesive remover. I was going to try that with a scraper. The issue is compounded by the PO installing the burgundy interior from an 87 930 using new glue over the old glue. Quite the mess!
For seats, I have two RSR seats from Vintage with the corduroy inserts, but movers packed the sliders and I can't find them!!!
Old 12-29-2013, 07:59 AM
I wouldn't use a scraper, especially a metal one. Not many flat areas, so you'll end up scratching the "overspray" that Porsche called "paint". They didn't paint the inside of the tub very well.
Once you get the glue soft enough, it comes right off.
JR
Old 12-29-2013, 08:08 AM
I used a plastic scraper and lots of elbow grease to strip mine. Took a couple rounds of citrus strip to get it clean.
I am not sure about the carpet padding. It's a decision I haven't been able make yet. I have some closed cel foam for the job, but there seems to be debate on if that is the right material.
Old 12-29-2013, 08:21 AM
I love the door panels & the trim for the pull, I would love to do that for my RS clone SC..
Old 12-29-2013, 08:45 AM
911 Besitzer
That burgundy steering wheel is incredibly cool. I have burgundy interior in my 84, and it has really grown on me. I take it that wheel is vintage, anyone know if they make them anymore?
1984 911 Targa
2008 BMW 128i
2007 Jeep Liberty
Old 12-29-2013, 03:04 PM
