expat's Avatar
Unhappy Trouble removing fuel filter
I can't break the nut on the lower part of the fuel filter. Top one came undone without too much grief but I just can't get the lower one to undo.
I can't use longer spanners because there is too little room and I've tried shooting some WD40 around the fitting but still no luck.
Suggestions?
Mark
Old 08-31-2002, 03:37 AM
Doug E's Avatar
Can you separate at another point and take everything over to the workbench and finish the project?
Doug
'81 SC Coupe
Old 08-31-2002, 03:43 AM
SK SK is offline
SK's Avatar
FYI - when I did this, I had the same problem. I did not use a flare wrench, and started to round off the nut. If you are not using a flare wrench, I would suggest you do.
Old 08-31-2002, 06:21 AM
Senior Member
Doug Zielke's Avatar
Flare wrench is a must!
Use two of them, and cross the wrenches like a scissor, and squeeze.
Tighten the same way.
*Warning*: Be sure to check for leaks immediately after starting the motor.
Some of the fittings on new filters are poorly machined, and will leak no matter how hard you tighten them.
'81 SC Coupe "Blue Bomber"
"Keep your eyes on the road, and your hands upon the wheel."- J.D.M.
Old 08-31-2002, 08:26 AM
