Deck Lid 'P O R S C H E' Drilling Template and/or Measurements?
Hello. I recently purchased a 1972 911T with a fiberglass rear deck lid sans any script. I've purchased the individual 'P O R S C H E' letters as I prefer the look of the original script instead of a blank tail and would like to drill to install.
I've looked all over the forum (and internet) for a decent template and or measure guide and unfortunately have not come up with anything of substance. I would prefer a template (as I believe that will help eliminate possible crooked or incorrectly spaced letters), but at a minimum can someone tell me how far up the 'S' is located from the bottom of the deck lid and the spacing between letters. I figured if I can't find a template, I could always start w/ the 'S' on centerline and work my way out. Any info/recommendations would be greatly appreciated. Thanks. |
I have a stock decklid without script sitting in my garage. I'll take some measurements for you tomorrow
Cheers! |
Bump...any ideas/info/help out there?
I spent HOURS researching the same thing and dug up some ancient info on the forum (and others). I am afraid I do not know who to give credit to for this photo originally (or WHERE I even found it) but it should get you pretty close to accurate and certainly close enough to look good! You will just have to extrapolate the location of the holes from the location of the letters and the pins on the back of them... Good luck with the drill :eek: http://forums.pelicanparts.com/uploa...1390360372.jpg |
How about..... cut out a cardboard strip and push the letters into it until you're satisfied with the layout. then, lay the cardboard over the rear deck and transfer the holes with a pencil / pen to the deck for drilling?
I took some measurements of the holes tonight, the hole diameter is 3mm.
All the measurements are taken from the edges of the decklid to the centre of the holes Camera battery is dead so here are some crappy ones from the iPadhttp://forums.pelicanparts.com/uploa...1390368314.jpg http://forums.pelicanparts.com/uploa...1390368358.jpg http://forums.pelicanparts.com/uploa...1390368376.jpg http://forums.pelicanparts.com/uploa...1390368392.jpg |
I happen to be doing this tomorrow, thanks very much JR and Islandhopper!
Wow...awesome guys, thanks everyone for all the info/pics. I'm going to make measurements and also use the cardboard idea (although I'm going to go w/ paper in order to help provide some level of flexibility to try and match the curve of the lid).
I'm still a little shocked there isn't a company that sells a drilling hole template as ideally that would be the easiest...guess I'll just have to create my own template. Again, thanks to all for the info and help...this one thread has provided more info than I've been able to find on the whole web for almost a week. Cheers! |
...one last thought... if you're around other Porsches ( breakfast club, social, etc.), ask if you can tape your paper strip over their letters and lightly trace the letters onto the paper. That may be the most accurate.
Thanks again to all for the info...planning on attempting to tackle this task sometime w/in the next few weeks. http://forums.pelicanparts.com/suppo...s/beerchug.gif |
Great post
If someone has a lid with no letters mounted, you could also do a pencil tracing (basically rub the side of a pencil's lead over the holes so they show up), and that would allow you to have a template of where to drill the mounting holes.
Alternately, some wax paper might allow one to see where the holes are located on the original lid and serve as a template if marked carefully. |
Someone else take this project on for the greater good! lol |
The template
http://forums.pelicanparts.com/uploa...1390956271.jpg http://forums.pelicanparts.com/uploa...1390956356.jpg OP has first shot at it |
I know this is an old thread, but I'm in the same boat as the OP. My painter ran off with most of my body panels (got the main shell back, thankfully), but the replacement read deck does not have the proper holes drilled.
The existing template mentioned above has already been tossed out, so I'm wondering if anyone else has one floating around? Thanks in advance for any and all help. |
This is a great post to begin with it should be bumped up once and a while. Some great ideas for a touchy job.
lazy-guy way.......
when I had to do this a while back I took the easy way out. cut off the pins and used double-sided molding tape. |
decklid template
I made a template to use for gluing Porsche lettering on my 964 deck lid. It took hours of research and measuring off photos and friend's 1970 911T. Mine came out nice. If anyone is interested. cheers.
http://forums.pelicanparts.com/uploa...1621021319.JPG |
| All times are GMT -8. The time now is 04:08 AM. |
