| non-whiner Join Date: Aug 2012 Location: Slightly right of center
				 | Quote:
				__________________ "Too much is just enough." | ||
|  01-24-2014, 12:52 PM |
| Registered Join Date: Jul 2000 Location: So. Calif.
			With a completely drained system, about 16 oz (typically, 1 can) is all it takes to fill and gravity bleed - minimal waste. With pressure bleeding, some have run through several pints of sometimes expensive fluid to rid the system of air.  Brake bleeding Sherwood | ||
|  01-24-2014, 02:00 PM |
| Fleabit peanut monkey | Quote:
 Could have been the beer, maybe?
				__________________ 1981 911SC Targa | ||
|  01-24-2014, 02:32 PM |
| NOS driver Join Date: Aug 2010 Location: Barcelona, Spain
			Just tried gravity bleedding in my 71 T with front S calipers, gravity bleeding seems to work fine with the rear calipers, but with the front ones when I loose the bleeders (I know is 2 on each caliper) I don't get any flow out of them until I start pressing the brake pedal. After some bleeding done by pushing on the brake pedal the feel is not too bad, but I cannot understand why gravity works on the rear calipers but not on the front ones. Any clues? luca | ||
|  04-03-2014, 01:44 PM |
| Registered |
				This is my method too.......
|  04-03-2014, 02:25 PM |
				 | Quote:
 MHO, Sherwood | ||
|  04-03-2014, 02:53 PM |
			Thanks Sherwood, I'm puzzled too. I should have mentioned that I bled the brakes after changing pads and putting new goodridge braided lines on the front calipers. the rear one are still the original ones as I was too afraid of damaging the hard lines and I need the car for the weekend. The brakes do bite a lot better, but the pedal still has a long stroke (as long as before I changed the lines and the pads). I wonder if air in the master cylinder would explain this. I believe the master cylinder is "dual" so front and rear calipers are somehow independent. thanks luca | ||
|  04-04-2014, 12:12 AM |
| Retired Member Join Date: Sep 2005 Location: Guelph Ontario
				 | Quote:
 I'm going to try the same thing this week but I'm going to use nitrogen to force the fluid.
				__________________ 80 911 SC sold 17 Tahoe 07 Z06 Corvette   | ||
|  04-07-2014, 04:11 PM |
