Am I missing a sill here? or some sort of trim piece?
Guys,
I picked up a 79 a few months ago and in the process of rebuilding it. Got a carpet kit - but wondering if it's missing some sills or something here? ![]() The reason that crossed my mind was because I was browsing the catalog today and came across a different variety of metal sills and was wondering on where they go and how they mount. Please offer up some advice! Thanks, Paul
03' Audi RS6; 16' 328i xDrive Touring; 13' X3 mSport, 91' e30 M52 |
Yep, you are missing the metal sill trim piece.
JR |
So I need either one (actually two) of these?
Pelican Parts - Product Information: 901-551-419-28-70K-OEM or Pelican Parts - Product Information: 901-551-419-50-OEM correct?
The alumium sill piece goes beside your rubber on top metal strip lift your carpet and you will see 6 hole for metal screw.
Almost Banned Once
My 78SC has silver ones... I'm not sure what was correct for a 79SC.
- Peter |
My '79SC has the silver ones
1979 911 SC Coupe 2000 VW Passat 1.8T |
There is "correct" and also "what looks best" with his carpet color.
JR |
imho silver goes for a G-model til end of silver window trim, believe it to be till early 76 at most.
later was black according to the standard black coatet window trim. but: just buy what you like best.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany Instagram: @elvnmisfit |
Black window trim became standard in 1980. No idea if they made the black carpet trim standard at the same time...
JR |
Just additional info... my 1980 had black window trim from the factory but silver door sill trim.
Kurt |
Did a quick check and found factory pictures showing it up through 1985. I've also seen a picture that was purported to be of an '86 car that had the bright trim, although both of my 1986 cars had black trim.
Still think black looks better with his carpet... JR |
Go-Kart Mozart
My early build '86 came with the silver trim. I swapped over to black. That was the only silver trim on the car and screamed at me every time opened the doors. I've got the silver trim in a box around here somewhere. -J
86 Carrera Every normal man must be tempted at times to spit on his hands, hoist the black flag, and begin to slit throats. H. L. Mencken |
FWIW...my 78 had bright sill trim as did my 84. The 78 was cork interior so the bright sill looked fine. The 84 has black interior/carpet and the bright sills I found to be annoying, they're black now....
1984 Carrera Targa |
Thread Tools | |
Rate This Thread | |
