Je Ne Sais Quoi = Targa
Mikey83835's Avatar
Suggestions for lightweight starter?
Are they the same as high-torque, or can they be one or the other? Supposedly there was a version for about $120 on fleabay but is now NLA?
I understand the original weighs about 16 pounds, lightweights go 5 to 8 pounds,
Will be on a 915 box, 3.6 motor,
'74 Targa lightweight widebody, 3.6 motor, big bars, Speedlines, Sold 2018,
'81 SC Targa with 3.2 spoilers, Webers, SSIs, 7&8X16 Fuchs, 911R style exhaust,
Had a '71 911S Targa in the 80's, miss it,
Had a '61 Roadster in the 70's, miss it also,
Old 01-22-2014, 08:27 PM
ischmitz's Avatar
Send a message via Skype™ to ischmitz
I believe they are the same thing. However, I had issues with mine where the little gear would chew up the ring gear. Do a search - there are similar stories out there and apparently you can shim the starter to improve matter. I ended up going back to the stock starter for several reasons:
- I do like the slower-spinning of the original Porsche starter. The high-torque starters make the car sound like a Chevy when cranking. It spins much faster.
- I got tired of dealing with the gear not engaging and chewing up the ring gear.
Honestly, the 8 pounds won't matter with a 3.6......
Ingo
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430
I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs
Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!!
How about a NoBadDays DualChip for 964 or '95 993
Old 01-22-2014, 10:05 PM
a.k.a. G-man
Geronimo '74's Avatar
I bought one from chris7 right here on the board (or chrisseven, can't remember)
They make an adapterplate for a starter originally coming from a modern dieselcar.
Hi torque and very lightweight! Only 2.7 kgs which is about under 6 lbs.
Very pleased with it! No grinding gear issues.
Old 01-23-2014, 01:46 AM
That's great info. Thanks.
Old 01-23-2014, 02:43 AM
Spiderman
Jesse16's Avatar
For my 87
I bought the "hi-torque" from our host. To me it seems to spin the motor slower than the stock unit but my starter rebuild person only got me a year out of his effort with the original bosch so I got the new unit. All you have to do is compare the new to old side by side to confirm the extension of the starter gear and know all will be good when installed or not. The new is smaller lighter but I didn't weigh. Has worked fine for 2 years. Not a complicated decision unless looking for something really special. Good luck.
Midnight Blue 08 Cayman S, Fun/Track
Black 12 VW-GTI, work
Mexico Blue 87 Carrera, sold, sad, not enough garage space.
Old 01-23-2014, 06:39 AM
I got a genuine 'hi-torque' (or high-torque, one of those is written right on it) from 'Automotion' back in 1994, and it's faithfully started my car (I'm guessing) some 20,000 times since then. So it's too early to tell, but so far I'm happy with it.
Chuck.H
'89 TurboLookTarga, 371k miles
Old 01-23-2014, 07:56 AM
KTL KTL is offline
Schleprock
KTL's Avatar
The starter on eBay used to $100 is now around $200. He uses an OEM Nippondenso starter motor if i'm not mistaken. Goes by the ebay ID name of hiperformanceusa but it appears he's not offering the 911 starter anymore.
I have one of the hiperformanceusa starters and its a pretty good unit. But comes with the thick shim if you happen to need it, which is hokey. I haven't put mine to a lot of use since I installed it when I last rebuilt the engine and the engine had an oiling failure soon thereafter. Just now getting the engine back together for next racing season.
The IMI starters that Pelican sells have been good but some people have had problems that may or may not be attributed to the starter not properly engaging the ring gear, so keep that in mind/do a search to help your decision. There's conflicting information whether or not a shim should be used with the IMI
starter ring failure twice in 3 weeks. HELP!!
If you want a no-hassle top quality lightweight starter, you can't go wrong with a Tilton Super Starter. Tilton parts are supreme quality Made in USA.
Pre-89 Porsche 911/914/930 Standard Duty Super Starter
Kevin L
'86 Carrera "Larry"
Old 01-23-2014, 08:12 AM
KTL KTL is offline
Schleprock
KTL's Avatar
Also note that the 993 tiptronic starter is a great replacement for the original Bosch starter. It's not truly "lightweight" but it is a considerable 3 lbs lighter than the stock starter.
Kevin L
'86 Carrera "Larry"
Old 01-23-2014, 08:14 AM
Vintage Motorsport
RichardNew's Avatar
I'm not sure it's really worth the effort unless you're a very serious racer.
Richard Newton
Race Car Images
Old 01-23-2014, 08:42 AM
The name, "High-torque" is a marketing tool for a common gear-reduction type motor. It really isn't high-torque. Instead of using a large and heavy high-torque motor to rotate the engine, a gear reduction motor uses gearing (small gear drives larger gear) to generate the minimum rotational force to start the engine. To compensate for the relatively light weight motor (weight savings here) and reduced current requirement, the smaller motor simply rotates at a faster speed. Thus, more rotational speed and the gearing makes up for the lower torque output of the motor.
This also reduces the electrical load on the battery during cranking which allows some to use a reduced capacity battery (careful about using this in freezing temperatures).
Gear reduction motor:
Direct drive motor:
A random lesson for the AM,
Sherwood
Old 01-23-2014, 11:14 AM
muck-raker
kidrock's Avatar
IIRC, there have been past threads relating to the amount of teeth on the throw out pinion (like Ingo stated earlier). Something about the high torque IMI units being sold with either 9 or 11 teeth, and not engaging properly with the ring gear. A quick search should yield results.
STONE
'88 Cabriolet, using EP Slick 20w50 partial synthetic Snake Oil...just as Rommel intended.
Deny Everything; Admit Nothing; and Always Make Counter-accusations
Old 01-23-2014, 11:53 AM
Mikey83835's Avatar
I sent him a PM, thanks,
Hi torque lightweight starter Q
"axial epicyclic gearbox" I have no clue,
Old 01-23-2014, 11:57 AM
Mikey83835's Avatar
Ingo
Richard Newton
Race Car Images
I would agree if that was all I was going to do, but in conjunction with plastic bumpers, hoods, possibly front fenders, deleting all the old-man-in-a-Buick-options like ac/cc/radio etc, lightweight interior and seats, light battery, etc, etc, one can make a substantial difference in the power-to-weight ratio,
Adding power is fine but decreasing weight gives the acceleration improvement also, plus better handling, braking, and even better gas mileage,
Old 01-23-2014, 12:18 PM
Think "planetary gears"...
Let us know what Chris says. I'm interested in the cost and availability.
JR
Old 01-23-2014, 01:09 PM
a.k.a. G-man
That's the one i have.
Chris is a good guy to deal with as well.
Old 01-23-2014, 01:26 PM
as far as light weight goes, the "rebuilt" bosch SR68X starters now come as a smaller, considerably lighter unit that looks like a new part. haven't got a big original style in quite a while.
206 637 4071
Old 01-23-2014, 01:33 PM
Mikey83835's Avatar
JR
$360 + shipping, designed for hi-compression motors, so more starter than I need for a stock-ish 993,
Old 01-25-2014, 10:46 PM
non-whiner
mreid's Avatar
Mikey, I have the same set up and used this one from our host:
Pelican Parts - Product Information: PEL-GE-STHT
No problems, yet, but only been running it for a few months. Avoid the cheaper versions as the cast nose has been known to self-destruct like this one did in my other car:
"Too much is just enough."
Old 01-26-2014, 05:55 AM
