Engine Locknuts:Nylon or Spring Washers on 1973 Engine!?
I am in the process of restoring a 1973 1/2 911 and putting my ENGINE parts and hardware together.
Q: Did nylon lock nuts exist in 1973 and if so, were they used on this year 911 or Was it a standard nut with spring washers as it seems the parts diagrams depict? Thanks All!
AutoBahned
Ny-locks will work a LOT better than a standard nut with spring washers unless they are in a very hot area.
Or are you nuts about concours? |
I totally agree... I am not going to show the car but am doing a restoration just on this side of perfect so,, I want to try to stay with original.
I remember that the gearbox nuts on my 1972 915 where like nylocs but are all metal with a sort of crimping section where the nylon is. I replaced them with nylocs, but kept regular nuts and lock washers on the engine fasteners. Maybe use both?
1972 911T Coupe with a '73E MFI engine and 'S' pistons 10 year resto mostly completed, in original Albert Blue. ***If only I didn't know now what I didn't know then*** |
non-whiner
Nylocks were not used on your year, but are much better than lock washers and the old style deformed steel lock nuts (except in high heat applications). I would use nylocks for the intake manifold and other areas where a loose nut could create a vacuum or fuel leak.
"Too much is just enough." |
| Tags |
| nylon lock nuts |
