m110's Avatar
8mm Extra Long Allen Socket
Sir Tool P243
Solid one piece construction needed for busting loose rusted bolts of heat exchangers/exhaust systems.
The extra long length easily accesses these hard to reach exhaust system bolts. 3/8" drive.
Applicable: Porsche model 911, 930.
http://www.pelicanparts.com/cgi-bin/ksearch/PEL_search.cgi?command=show_part_page&please_wait=N&make=POR&model=TOOL&section=WTD026&page=123&bookmark=7&part_number=PEL-TOL-P243
1988 Carrera Coupe
Old 01-31-2014, 08:15 PM
French Import
zippy_gg's Avatar
Originally Posted by Tidybuoy View Post
Are some of the nuts special "allen" nuts? I better take a closer look, and in the daytime. So far, I have only seen copper hex nuts - and they are 12mm.
Yes the ones you are accessing through the holes in the heat exchangers are.
Gilles & Kathy
Happiness is not having a Porsche in the garage... Happiness is having a Porsche on the road!
86 Porsche 911 Cabriolet, 2011 BMW 1200RT, 03 Saab 93 Cabriolet, 06 MB E350 Estate
Old 01-31-2014, 09:06 PM
Cooper911SC's Avatar
What Zippy said. The access holes through exchangers lead to what are called Barrel Nuts. 8mm Allen.
The rest are either 12mm or 13mm steel or copper lock nuts.
If you have a set of long Allen wrenches you can use the 8mm long end through the exchanger and just do the "linked wrench" trick with say a 19mm box end wrench on the short arm for leverage.
Cooper
Old 01-31-2014, 09:40 PM
