-   -   Don't like my fogs (http://forums.pelicanparts.com/porsche-911-technical-forum/794495-dont-like-my-fogs.html)
toddu 01-31-2014 06:50 PM
Don't like my fogs
What to do? different valance? Just take them off?
http://forums.pelicanparts.com/uploa...1391223016.jpg
Todd
SilberUrS6 01-31-2014 06:55 PM
Take them off.
I hate mine, too. I'd love to do something useful with the holes created from taking them out. Additional ducting for oil cooling? For running another front AC condenser? I think there must be a good use for those holes, other than crap foglights.
porsche930dude 01-31-2014 07:03 PM
yup just paint some plugs. you can get that stuff at any hardware or autoparts store
porwolf 01-31-2014 07:03 PM
Originally Posted by SilberUrS6 (Post 7886485)
Take them off.
How about just plugging the holes up:
http://www.heyco.com/Hole_Plugs/
Arne2 01-31-2014 07:33 PM
Mine will be gone when I get around to painting the car. Absolutely worthless. Cr@p light output (even for fog lights, for which I always have low expectations), and yet expensive to repair if a rock breaks a lens.
Since my valance is bent and has filler from previous repair, I will just replace it with a new CS-style.
SilberUrS6 01-31-2014 07:53 PM
On a 3.2, they are mounted in the valance.
Arne2 01-31-2014 07:55 PM
Here's the plan for my 3.2, works for SC as well:
Repro steel valance
toddu 01-31-2014 08:10 PM
Repro steel valance
Hmmmm..... interesting.
Todd
DougZ 02-01-2014 05:12 AM
I would keep them. I like the stock look. Your car looks great just the way it is!!
gamin 02-01-2014 05:18 AM
Why not a 3.2 valance? At least the fogs don't look like an after thought. And you get a cutout for air to the front oil cooler.
Flojo 02-01-2014 05:39 AM
delete 'em.
i did too. one I was stock-look convinced too.
but today Im happy, as it gives the front a nicer, clearner look.
who need fogs on a fun-car anyway?
rubber plugs for the holes.
javadog 02-01-2014 05:42 AM
Even cheaper than buying a repro valance, just have a body shop get rid of all the holes for you. If you don't run a front plate, lose those holes, too. While you're at it, remove the gravel guard sprayed on the inside. You'll end up with a nice little weight loss and you'll never miss the fog lights.
JR
toddu 02-01-2014 06:24 AM
JR - I had thought about welding up the holes myself.
Maybe I'll look at them when it ever warms up. Ars deep in an engine replacement at the moment.
Todd
nineball 02-01-2014 06:52 AM
i changed my SC to the later style valance and i am quite happy. the stock sc fogs, to me, always looked like someone at the factory forgot to install them, caught it at the last minute and stuck them on.
widgeon13 02-01-2014 08:17 AM
That was the style back in the 80's. Everything wasn't form fit to the car back then.
Arne2 02-01-2014 09:16 AM
JR
For an SC with a nice condition valance, yes. For us Carrera 3.2 owners? not so much.
Alan Lindquist 02-01-2014 09:22 AM
This is my 1980 SC. I used to run a late 80's valence with the fogs tucked in. A few rocks took care of that idea. Instead of replacing the fogs, I replaced the valence with an earlier version that had just the holes for the "outboard" fogs. I had a friend weld up the holes and did some body work and then sprayed it with rhino liner from a rattle can. (easy cause the car is black). I also drilled out the struts and tucked the bumper. I made an air scoop for the passenger side "extra" side marker space with schedule 40 PVC and plexiglass, epoxy, bondo, and wrapped it in carbon fiber looking vinyl. I used the vinyl to wrap the driver side marker light since it was half hidden by the bumper tuck into the accordions. http://forums.pelicanparts.com/uploa...1391275341.jpg
javadog 02-01-2014 09:25 AM
You can fill in those holes, too. Or make cooling ducts out of them. Or trade your valance and washer fluid tank to an early car owner for an earlier style valance.
Etc.
JR
redridge 02-01-2014 09:31 AM
your just bored... p-cars looks great in stock form.
Tidybuoy 02-01-2014 12:15 PM
Personally, I like the fogs. My '74 does not have them but I may add the "built in" fogs that are on the Carrera valence, some day.
If you really hate yours, you could get a '74 valence and then add the spoiler lip.
Here's mine (no spoiler lip), wish I had one.
http://forums.pelicanparts.com/uploa...1391285729.jpg
